Legacy Personal Blogs Atmel SAMA5D4 Xplained Ultra Road Test -- Building a QT application
  • Author Author: pettitda
  • Date Created: 27 Mar 2015 5:37 PM Date Created
  • Views 1047 views
  • Comments 5 comments
  • RoadTest
  • sama5d4
  • atmel_sama5d4
pettitda
pettitda
27 Mar 2015
In order to create an QT application to run on the Atmel SAMA5D4 Xplained Ultra board, I did the following:
1. From the Linux4SAM PokyBuild < Linux4SAM < TWiki page:
a) bitbake meta-toolchain-qte
b) sudo tmp/deploy/sdk/poky-eglibc-i686-meta-toolchain-qte-cortexa5t2hf-vfp-neon-toolchain-qte-1.6.1.sh
c) source /opt/poky/1.6.1/environment-setup-cortexa5t2hf-vfp-neon-poky-linux-gnueabi
2. From the QT tutorial Getting Started Programming with Qt | Qt 4.8:
a) create ~/try_qt/hello.cpp using the code snippet from the tutorial
b) qmake -project
c) qmake
d) make
3. Copy the resultant executable (try_qt) over a thumb drive and then plug the thumb drive into the Atmel board
4. Connect to the board using putty, mount the thumb drive at /media/david, and move to that directory
5. Run the executable
a) ./try_qt -qws
Here's what it looks like:
The image that I used was the "atmel-qt4e-demo-image" that i built earlier.
  • pettitda
    pettitda over 10 years ago in reply to clem57 +1
    It's a PDA TM4301.
  • sharonroyal
    sharonroyal over 7 years ago
    My sama5d4 xplained board is booting from Qt demo image developed from sources.
    I downloaded and installed the tool chain (poky-atmel-glibc-x86_64-meta-toolchain-qt5-cortexa5hf-vfptoolchain-2.0.1.sh).
    Download the Qtcreator v.4.5.1 and set QT-SDK Environment variable with qtcreator.
    Set the compiler path, qmake path and gone for the device test.
    Atlast when I build a sample Qt project, following issue is displayed.
    :-1: error: c: Command not found
    The compile output is 05:02:22:
    Running steps for project test2... 05:02:22: Starting: "/usr/bin/make" clean rm -f moc_predefs.h rm -f moc_mainwindow.cpp rm -f ui_mainwindow.h rm -f main.o mainwindow.o moc_mainwindow.o rm -f *~ core *.core 05:02:22: The process "/usr/bin/make" exited normally. 05:02:22: Configuration unchanged, skipping qmake step. 05:02:22: Starting: "/usr/bin/make" /opt/poky-atmel/2.5.1/sysroots/x86_64-pokysdk-linux/usr/bin/qt5/uic ../test2/mainwindow.ui -o ui_mainwindow.h c -pipe --sysroot=/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi -std=c++11 -g -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_QML_DEBUG -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I../test2 -I. -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5 -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtPrintSupport -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtWidgets -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtGui -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtCore -I. -I. -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -o main.o ../test2/main.cpp Makefile:517: recipe for target 'main.o' failed c -pipe --sysroot=/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi -std=c++11 -g -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_QML_DEBUG -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I../test2 -I. -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5 -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtPrintSupport -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtWidgets -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtGui -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtCore -I. -I. -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -o mainwindow.o ../test2/mainwindow.cpp make: c: Command not found make: [main.o] Error 127 (ignored) make: c: Command not found make: [mainwindow.o] Error 127 (ignored) make: pipe: Command not found Makefile:521: recipe for target 'mainwindow.o' failed pipe --sysroot=/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi -std=c++11 -g -std=gnu++11 -Wall -W -dM -E -o moc_predefs.h /opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/lib/qt5/mkspecs/features/data/dummy.cpp Makefile:493: recipe for target 'moc_predefs.h' failed /opt/poky-atmel/2.5.1/sysroots/x86_64-pokysdk-linux/usr/bin/qt5/moc -DQT_DEPRECATED_WARNINGS -DQT_QML_DEBUG -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB --include ./moc_predefs.h -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -I/home/sharonmathew/QtCreator_Programs/test2 -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5 -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtPrintSupport -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtWidgets -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtGui -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtCore -I. ../test2/mainwindow.h -o moc_mainwindow.cpp make: [moc_predefs.h] Error 127 (ignored) Warning: Failed to resolve include "./moc_predefs.h" for moc file ../test2/mainwindow.h c -pipe --sysroot=/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi -std=c++11 -g -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQT_DEPRECATED_WARNINGS -DQT_QML_DEBUG -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_CORE_LIB -I../test2 -I. -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5 -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtPrintSupport -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtWidgets -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtGui -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/include/qt5/QtCore -I. -I. -I/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++ -o moc_mainwindow.o moc_mainwindow.cpp Makefile:524: recipe for target 'moc_mainwindow.o' failed sysroot=/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi -o test2 main.o mainwindow.o moc_mainwindow.o -L/opt/poky-atmel/2.5.1/sysroots/cortexa5hf-vfp-poky-linux-gnueabi/usr/lib -lQt5PrintSupport -lQt5Widgets -lQt5Gui -lQt5Core -lpthread make: c: Command not found make: [moc_mainwindow.o] Error 127 (ignored) /bin/sh: 1: -o: not found make: [test2] Error 127 (ignored) Makefile:192: recipe for target 'test2' failed 05:02:22: The process "/usr/bin/make" exited normally. 05:02:22: Elapsed time: 00:00.
    Help me please to solve this one.
  • pettitda
    pettitda over 7 years ago in reply to sharonroyal
    I found this on a google search:  https://stackoverflow.com/questions/36203211/c-command-not-found-error
  • sharonroyal
    sharonroyal over 7 years ago in reply to pettitda
    I tried all those but couldn't run qt creator.
  • sharonroyal
