Legacy Personal Blogs Atmel SAMA5D4 Xplained Ultra Road Test -- Days 4, 5, and 6
  • Author Author: pettitda
  • Date Created: 3 Mar 2015 11:09 PM Date Created
  • Views 761 views
pettitda
pettitda
3 Mar 2015
Over the last three days I've set up a virtual machine (VirtualBox) running Ubuntu 14.04LTS, pulled the Yocto/Poky source, and created the build environment using the instructions listed at PokyBuild < Linux4SAM < TWiki.  All of this went surprisingly well with no hitches.  However, I did find that the build went a lot faster once I allowed the virtual machine to use eight cores instead of one!  I created all three images as well as Atmel Poky QT-embedded SDK.
From there I went on to compile a simple "Hello World" application using the cross compiler from above.  However at this point, I'm unsure how to get this newly created application into one of the images to transfer over to the target.  That will be my goal for tomorrow.
Here's a list of some links I found helpful during this process:
Yocto Project Quick Start
Yocto Project Development Manual
Yocto Project Application Developer's Guide
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago +1
    Good work so far, I will continue to read up on your posts, good luck with this review
  • pettitda
    pettitda over 11 years ago in reply to noglitch +1
    Nicolas noglitch , Is the Atmel Poky QT-embedded SDK that I built above the equivalent of ADT described in the Yocto documentation? Can I use Yocto ADT and the Eclipse plug-in to develop and/deploy an…
