Legacy Personal Blogs Combined NFC reader / keypad
  • Author Author: Fred27
  • Date Created: 25 Oct 2018 9:12 PM Date Created
  • Views 2318 views
  • Likes 11 likes
  • Comments 15 comments
  • nfc
  • msp430
  • trf7970a
  • capacitive touch
Fred27
Fred27
25 Oct 2018
So, the board is back from the fab. It looks really nice - especially as it only cost $1 (+$8 shipping) for 3 from Seeed. It's been pasted, populated and toasted and ready for test. Well - it would be ready for test if it wasn't missing just one component - an out-of-stock 32.768kHz crystal.
The board will eventually be the way into my house. There's a small NFC antenna that I'm hoping will be tuned well enough for the tiny NFC implant in my hand. There's a capacitive touch keypad (hence the MSP430FR2633 microcontroller) because even I don't think getting my kids chipped is a great idea.
Unfortunately without the missing crystal it will be a pain to get the capacitive touch or the SPI comms with the TRF7970A NFC transceiver working. I'll wait for it and work on other stuff for now.
I can confirm that the reverse mount RGB LED that shines through the circular gap in the soldermask seems to work really well though. The FR4 diffuses it nicely. Blinky is always a good start to prove the MSP430 is running happily. I'll have to wait to see how my QFN soldering went. It looks borderline under the microscope. This time I decided to solder down the thermal pad first and check alignment and then use some paste and a hot air gun to do the leads. That should minimise the chance of any shorts under there that I can't see. At least I hope it does - I've never tried it that way before.
    shabaz over 8 years ago in reply to genebren +4
    Hehe I've been looking too (since I'm close by). I've found some wire-ended ones that are about the size of those in old casio watches (about 2mm dia, 6mm long maybe) part code AB26TRB-32.768KHZ-T and…
  • Fred27
    Fred27 over 8 years ago +3
    Thanks for the advice about bodging in another crystal. I did that, adapted some basic NFC reading code and what do you know - it works! Despite my questionable QFN soldering and guesswork at antenna tuning…
  • Fred27
    The capacitive touch keypad is also working pretty well, including decoding key presses and checking for the right code. The proximity / guard sensor works, but may need some tuning so I've disabled it…
  • BigG
    BigG over 8 years ago
    I love the inclusion of the NFC antenna.
    Did you refer to any design guides to make this. What trace width did you use, for example.
    I'm very much a noob here, so was wondering how did you "tune" that antenna, as in choose the correct resistor & capacitance values for the antenna.
  • Fred27
    Fred27 over 8 years ago in reply to BigG
    The design is based on one that I did previously using a wirewound inductor as an antenna.
    https://0xfred.wordpress.com/2016/03/04/nfc-login-2-1/
    I don't have the equipment (or the skills if I'm honest) for tuning an antenna so the PCB coil should be about 1uH to match tuning circuit values from other commercial designs. I've also knocked up another PCB with various attempts at trial-and-error antenna design. Nobody else seems to have done any work trying to tune a PCB antenna to an implanted NFC tag. The small size and the fact that the centre line of the coil will be aligned parallel to the board make it difficult to couple.
  • Fred27
