Legacy Personal Blogs Configurable 5V Raspberry Pi I/O Card on Kickstarter
  • Author Author: land-boards
  • Date Created: 25 Dec 2014 7:40 PM Date Created
  • Views 838 views
land-boards
land-boards
25 Dec 2014
I have a Configurable 5V I/O card for the Raspberry Pi on Kickstarter.
photo-1024x768.jpg?1418517849
Features
  • All Raspberry Pi I/O lines
  • 8-bit bidirectional 3.3V to 5V level translator
  • Fuses on 3.3V and 5V power lines
All of the Raspberry Pi I/O connections are brought to GVS connectors. This is:
  • (8) GPIO lines on GVS connectors
  • (2) SPI interfaces (can be configured as 5 GPIO lines)
  • (1) UART interface (can be configured as 2 GPIO lines)
  • (1) I2C interface(can be configured as 2 GPIO lines)
Level translators
The board uses an 8-bit wide Texas Instrument TXS0108 voltage translator to convert up to 8 of the 3.3V I/O lines to 5V I/O levels.
Fuses
  • The board has Resettable fuses on the 3.3V and 5V from the Raspberry Pi.
  • These fuses protect your Raspberry Pi from overloads.
  • These fuses are 1/2 Amp PTC fuses.
  • PTC fuses have certain advantages (they are self healing) and disadvantages (they are not like a wire fuse which acts like a switch).
  • If you trust your wiring you may choose to solder a wire over the fuse.
    • Care should be taken when doing so.
  • land-boards
    land-boards over 11 years ago
    Good comments. Thanks,
    Doug
  • land-boards
    Doug
