Legacy Personal Blogs CPLD Controlled Door Lock - Input Circuit
  • Author Author: oldmanraskers
  • Date Created: 25 Apr 2015 9:22 AM Date Created
  • Views 1657 views
  • Comments 11 comments
  • max_v_cpld
oldmanraskers
oldmanraskers
25 Apr 2015
Input Circuit
The input circuit is very simple. Consider that 24V is present at the connector X1-1; this will allow 20mA to flow through LED1 and indicate there is an input present.  Approximately 2mA will flow via R2 and R3, thereby pulling the CPLD IN01 pin to 3V (the device can accept unto 4V).
  • michaelkellett
    michaelkellett over 11 years ago in reply to oldmanraskers +1
    You're mixing up output drive currents and input currents. The MAXV will draw a tiny 10uA current on an input (unless you program a pullup current for that pin) so when Q1 is off you would expect to see…
  • michaelkellett
    I can't see anything when I click on your link - can you embed the picture using the little camera icon ?
    MK
  • oldmanraskers
    oldmanraskers over 11 years ago in reply to michaelkellett
    Not sure what has happened here - I did embed the image via the camera icon image
  • oldmanraskers
  • michaelkellett
    Try putting it into a discussion post for now - or give us a Dropbox link if you use Dropbox.
    MK
  • oldmanraskers
    I've uploaded it here as JPEG - hopefully that will make some difference.
