Legacy Personal Blogs CPLD Controlled Door Lock - Soldering the CPLD
  • Author Author: oldmanraskers
  • Date Created: 24 May 2015 2:49 PM Date Created
  • Views 900 views
  • max
  • max_v_cpld
oldmanraskers
oldmanraskers
24 May 2015
I am now in the process of redesigning the circuit to accommodate a larger pin pitch CPLD, since soldering the 100 pin package proved very difficult image and I trashed three of them - admittedly I was better each time but I still ripped up tracks, moved pads, etc. etc. So... back to the drawing board.
  • johnbeetem
    johnbeetem over 11 years ago +1
    I would definitely look into SchmartBoard for a 100-pin TQFP: http://schmartboard.com/index.asp?page=products_qfp&id=68 However, see if you can get away with a Xilinx XC9536XL or XC9572XL in a 44-pin PLCC…
  • johnbeetem
    However, see if you can get away with a Xilinx XC9536XL or XC9572XL in a 44-pin PLCC.  You can even socket those with 0.1" through-hole pins.
    Or find a cheap CPLD module that already has the CPLD soldered on and has 0.1" connectors you can adapt, or has room for prototyping the rest of your circuitry.
  • johnbeetem
