Currently I am investigating the lifetime or MTBF of GM Tubes.
Usually a maximum of Counts is specified on GM Tubes.
For example the SBM-20 from Russia has a total pulses lifetime of: at least 2*1010
''GSTube.com''. Tubes, sockets etc. Parameters and characteristics SBM-20
However I have noticed that Tubes seem to get damaged faster than my expectation.
My Radex RD1503's SBM-20 GM tube died this year after hardly having used it.
Before some other tubes for older analog equipment also perished but with these I cannot rule out that the tubes were already used for a long time.
I would expect other sources of impact than normal usage as the single cause of malfunctioning of the GM Tube.
- Earthquake, shaking or dropping?
- Unexpected over Voltage?
- Preservation other than non-active/off-power needed?
To be able to monitor and rule out the maximum pulses when active as single cause the total accumulated pulses should be stored.
This could be done with the normal total Dose functions on many digital GM counters.
Of course you cannot be sure when the GM Tube was bought through an online auction like Ebay, that the Tube wasn't already used before.
Making a new GM counter with a LND712 GM Tube which has no lifetime specified...
LND, Inc. OCEANSIDE NEW YORK - Designers and Manufacturers of Nuclear Radiation Detectors
Project progress to be continued.....
e14 Contributor
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
e14 Contributor
in reply to e14 Contributor
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
Comment-
e14 Contributor
Cancel
Vote Up
0
Vote Down
Sign in to reply
More
Cancel
