Legacy Personal Blogs Geiger Mueller counter's Tube protection and preservation
  • Date Created: 17 Jul 2015 7:20 AM Date Created
  • Views 2337 views
  • Comments 7 comments
  • preservation
  • Mueller
  • pulses
  • geiger
  • tube
  • maximum
  • counter
  • protection
  • gm
  • mtbf
  • lifetime
e14 Contributor
e14 Contributor
17 Jul 2015
Currently I am investigating the lifetime or MTBF of GM Tubes.
Usually a maximum of Counts is specified on GM Tubes.
For example the SBM-20 from Russia has a total pulses lifetime of: at least 2*1010
''GSTube.com''. Tubes, sockets etc. Parameters and characteristics SBM-20
However I have noticed that Tubes seem to get damaged faster than my expectation.
My Radex RD1503's SBM-20 GM tube died this year after hardly having used it.
Before some other tubes for older analog equipment also perished but with these I cannot rule out that the tubes were already used for a long time.
I would expect other sources of impact than normal usage as the single cause of malfunctioning of the GM Tube.
  • Earthquake, shaking or dropping?
  • Unexpected over Voltage?
  • Preservation other than non-active/off-power needed?
To be able to monitor and rule out the maximum pulses when active as single cause the total accumulated pulses should be stored.
This could be done with the normal total Dose functions on many digital GM counters.
Of course you cannot be sure when the GM Tube was bought through an online auction like Ebay, that the Tube wasn't already used before.
Making a new GM counter with a LND712 GM Tube which has no lifetime specified...
LND, Inc. OCEANSIDE NEW YORK - Designers and Manufacturers of Nuclear Radiation Detectors
Project progress to be continued.....
    e14 Contributor over 10 years ago in reply to e14 Contributor
    JIj bent zeker Tjerk die net over de pubertijd heen is image?
    e14 Contributor over 10 years ago in reply to GJZ
    GJ, Thanks that is more than twice the total amount of counts expected for SBM20 from Russia. Wonder why they don't publish this significant spec openly though. When close to a leaking reactor like Fukushima this will be reached fast and preventive maintenance cq replacement can be anticipated on e.g. when operating in an environment of 3000cpm for more than 277 hours (5E10^10/3000/60) the tube will likely stop functioning.
  • clem57
    clem57 over 11 years ago in reply to GJZ
    This is true for a discussion  to check as a question not for a blog for anyone that needs. Just saying.
    C
  • GJZ
    GJZ over 11 years ago
    Fred if you post this as a question (tick the checkbox that it is a question when you write your something in your blog) then we can answer it. It will also marked it as answered when you have sufficient feedback.
    Ben jij Fredje zoals Gert Jan dat altijd zegt?
