Legacy Personal Blogs Geiger Mueller counter's Tube protection and preservation
  • Date Created: 17 Jul 2015 7:20 AM Date Created
  • Views 2360 views
  • Comments 7 comments
  • preservation
  • Mueller
  • pulses
  • geiger
  • tube
  • maximum
  • counter
  • protection
  • gm
  • mtbf
  • lifetime
e14 Contributor
e14 Contributor
17 Jul 2015
Currently I am investigating the lifetime or MTBF of GM Tubes.
Usually a maximum of Counts is specified on GM Tubes.
For example the SBM-20 from Russia has a total pulses lifetime of: at least 2*1010
''GSTube.com''. Tubes, sockets etc. Parameters and characteristics SBM-20
However I have noticed that Tubes seem to get damaged faster than my expectation.
My Radex RD1503's SBM-20 GM tube died this year after hardly having used it.
Before some other tubes for older analog equipment also perished but with these I cannot rule out that the tubes were already used for a long time.
I would expect other sources of impact than normal usage as the single cause of malfunctioning of the GM Tube.
  • Earthquake, shaking or dropping?
  • Unexpected over Voltage?
  • Preservation other than non-active/off-power needed?
To be able to monitor and rule out the maximum pulses when active as single cause the total accumulated pulses should be stored.
This could be done with the normal total Dose functions on many digital GM counters.
Of course you cannot be sure when the GM Tube was bought through an online auction like Ebay, that the Tube wasn't already used before.
Making a new GM counter with a LND712 GM Tube which has no lifetime specified...
LND, Inc. OCEANSIDE NEW YORK - Designers and Manufacturers of Nuclear Radiation Detectors
Project progress to be continued.....
  • GJZ
    GJZ over 11 years ago
    I got a reply for the LND device:
    Life expectancy in a GM tube is expressed in counts and is 5E10 counts.
    If stored in a cool dry place, free from continuous or severe vibration, there is hardly any deterioration in the tubes characteristics. A storage life of
    years is not unusual.
    In your case Earthquake could be a problem. If you need more or other information please contact me.
  • GJZ
    e14 Contributor over 10 years ago in reply to GJZ
    GJ, Thanks that is more than twice the total amount of counts expected for SBM20 from Russia. Wonder why they don't publish this significant spec openly though. When close to a leaking reactor like Fukushima this will be reached fast and preventive maintenance cq replacement can be anticipated on e.g. when operating in an environment of 3000cpm for more than 277 hours (5E10^10/3000/60) the tube will likely stop functioning.
