Legacy Personal Blogs Getting Started with an Old Raspberry Pi #1 : Its a Model B (not a B+)
  • Author Author: dubbie
  • Date Created: 18 Feb 2019 12:35 PM Date Created
  • Views 5865 views
  • Comments 17 comments
  • raspberrry pi
dubbie
dubbie
18 Feb 2019
As I am thinking of taking part in the Picasso Design Challenge that uses a Raspberry Pi 3 B+ and not knowing very much about any Raspberry Pi I thought I would borrow one and see what I could do. I obtained an old one from my son which I am now attempting to get going.
I have searched some of the Element14 older material and managed to find out that I have a Raspberry Pi Model B (but not a B+). But so far I have not been able to find out how to connect it up so that I can at least turn it on and see what happens.  I think I need an HDMI cable but what else? Can anyone point me in the right direction for this very old Pi which is way past its Best Before Date?
Dubbie
  • ralphjy
    ralphjy over 7 years ago +6
    I would hate to discourage you, but if I were just starting out - I would just buy a new RPi 3B+ as a kit with power supply, pre-loaded SD card and case. I think you'll find that the old model RPi will…
  • luislabmo
    luislabmo over 7 years ago +5
    Hi dubbie , The minimum necessary to use a Raspberry Pi: First identify which RPi you have , this way is going to be less painful to deal with issues and also the GPIO mapping may be different, so this…
    beacon_dave over 7 years ago +5
    Perhaps have a read through these MagPi official guides to get a basic overview of the R-Pi: https://www.raspberrypi.org/magpi-issues/QuickStart_v1.pdf https://www.raspberrypi.org/magpi-issues/Beginners_Guide_v1…
  • ralphjy
    I would hate to discourage you, but if I were just starting out - I would just buy a new RPi 3B+ as a kit with power supply, pre-loaded SD card and case.  I think you'll find that the old model RPi will cause you a lot of issues with lack of memory, CPU power and no wireless.  Unless you have a compelling reason for using the old RPi, you'll have a much better experience with the latest one.  It is somewhat counter-intuitive, but a full featured unit will be easier to learn because you don't have to worry so much about constraints when running example programs.  After you get experience, then you can optimize the hardware selection for features, size and power.
    That being said, if your son had used the RPi previously, it probably has a bootable SD card so you'll just need to add a USB keyboard/mouse and HDMI/DVI display to check it out as Luis has suggested.  One caveat for a newbie, if you get running - make sure you shutdown the OS before powering off as there is a reasonable chance to corrupt your SD image otherwise.
    • Vote Up +6 Vote Down
    dubbie over 7 years ago in reply to ralphjy
    Ralph,
    I was hoping to just use the old Raspberry Pi as part of my learning curve to get started with something simple in order to provide at least some possibility of being able to complete a possible Picasso Design Challenge project. If I think I might be able to do something then I was planning to buy the 3B+ as it is a requirement of the Design Challenge anyway.
    I've made some progress in getting my old Raspberry Pi running but still need a keyboard. And a power supply.
    Dubbie
    Ralph,
    Dubbie
