Legacy Personal Blogs Getting Started with an Old Raspberry Pi #1 : Its a Model B (not a B+)
  • Author Author: dubbie
  • Date Created: 18 Feb 2019 12:35 PM Date Created
  • Views 5865 views
  • Comments 17 comments
  • raspberrry pi
dubbie
dubbie
18 Feb 2019
As I am thinking of taking part in the Picasso Design Challenge that uses a Raspberry Pi 3 B+ and not knowing very much about any Raspberry Pi I thought I would borrow one and see what I could do. I obtained an old one from my son which I am now attempting to get going.
I have searched some of the Element14 older material and managed to find out that I have a Raspberry Pi Model B (but not a B+). But so far I have not been able to find out how to connect it up so that I can at least turn it on and see what happens.  I think I need an HDMI cable but what else? Can anyone point me in the right direction for this very old Pi which is way past its Best Before Date?
Dubbie
  • ralphjy
    ralphjy over 7 years ago +6
    I would hate to discourage you, but if I were just starting out - I would just buy a new RPi 3B+ as a kit with power supply, pre-loaded SD card and case. I think you'll find that the old model RPi will…
  • luislabmo
    luislabmo over 7 years ago +5
    Hi dubbie , The minimum necessary to use a Raspberry Pi: First identify which RPi you have , this way is going to be less painful to deal with issues and also the GPIO mapping may be different, so this…
    beacon_dave over 7 years ago +5
    Perhaps have a read through these MagPi official guides to get a basic overview of the R-Pi: https://www.raspberrypi.org/magpi-issues/QuickStart_v1.pdf https://www.raspberrypi.org/magpi-issues/Beginners_Guide_v1…
  • jomoenginer
    jomoenginer over 7 years ago
    Is this what you have?
    https://www.element14.com/community/message/171871/l/raspberry-pi-1-model-b-io-connector-pinout#171871
    https://makezine.com/projects/tutorial-raspberry-pi-gpio-pins-and-python/
    Outside of being a bit slower and less RAM and no WiFi and no HDMI, it should not be much different than the new ones. That is unless the newer images do not run on this.
    Can you post an image of the top of the board to show the revision?
    dubbie over 7 years ago in reply to jomoenginer
    Jon,
    These are really useful links, just the sort of thing I was looking but for some reason couldn't find. I guess you need the right keywords when searching. The pinout diagram is really useful, something about the Pi I can actually understand, plus th second link to using Python and Pi was going to be my first step once I can actually talk to the Pi. Ralph Yamamoto gave me a good link for using Ethernet to connect to the Pi so if that works I'll be on my way.
    Dubbie
    Jon,
    Dubbie
