Legacy Personal Blogs Google AIY Voice Kit Test
  • Author Author: korn
  • Date Created: 15 Oct 2018 2:57 AM Date Created
  • Views 1965 views
  • Likes 9 likes
  • Comments 8 comments
  • google aiy
  • raspberry pi
korn
korn
15 Oct 2018
With wake phrase
With Button press
  • korn
    korn over 8 years ago +2
    dixonselvan Heres the video's I promised.... Couldn't figure out how to reply with them to you directly. Not bad for a $5 kit from MicroCenter and It answers faster than Alexa does........
  • dixonselvan
    dixonselvan over 8 years ago in reply to korn +2
    Thank you very much korn Is this the kit you are referring to? https://aiyprojects.withgoogle.com/voice/ This costs around $30+. Can you please share the link of the kit or like where to buy it for $5…
  • korn
    korn over 8 years ago in reply to dixonselvan +2
    I bought a few 4 mic re-speaker arrays to try to do the alexa light ring dir pointing thing. not sure when I'll be able to play with those. Ill post something about them when I unbox one. theres two versions…
  • mfetting
    mfetting over 7 years ago
    If you want stereo, add the MAX98357A I2S 3W Class D Amplifier Breakout Interface I2S DAC Decoder Audio.  It is available at Adafruit or Aliexpress.
    Both products include all the parts to attach it to the board and connect a speaker.
  • dixonselvan
    Thank you korn for so much useful information and a detailed explanation of the advantage of V1 over V2.
    Good luck on your directional mic array LED project similar to Amazon Echo Devices!
  • korn
    korn over 8 years ago in reply to korn
    for comparison heres the v2 bonnet....
    no servo connectors or mosfet drivers.....
  • korn
    I think those little sot G31 drivers are 20V 6A mosfets
    DMG3420U-7 | N-Channel 20 V 29 mOhm Surface Mount .
    I could have used that for my ring leds on the pi cam instead of the big to220 mosfet I did use.....
  • korn
    heres the extra connectors of the V1.
    If your just building a google assistant you wont really care if you don't have these but I have other plans for mine....
    6 servo connectors and 4 mosfet outputs among others...
    I have to add the 5V coaxial jack to this one....
