Legacy Personal Blogs Help with high volt transistor
  • Date Created: 25 Feb 2015 7:25 PM Date Created
  • Views 1216 views
  • Comments 7 comments
  • amplifiers
  • transistors
  • electronics
  • power
  • solid_state
e14 Contributor
e14 Contributor
25 Feb 2015
Hello,
I am trying to find a transistor or amplifier that can work with large voltages, like 100 kilovolts. I am trying to build an x-ray machine and need the transistor to vary the voltages with an Arduino. The transistor will separate the Arduino from the high voltages.
Is there a place I could find that kind of transistor or amplifier? Ideas or options that are alternative approach to my problem are welcome.
    jw0752 over 11 years ago +1
    Hi Eddy, There are 2 things to control with respect to x-ray tubes. The high voltage will control the energy of the x-rays that are produced. Higher voltage produces a shorter wave length higher energy…
  • gilshultz
    gilshultz over 11 years ago
    Look at a crossatron Switch as a possible solution.  Why not consider switching the lower voltage primary, if you are at mains voltage the price gets very reasonable.
  • gilshultz
    e14 Contributor over 11 years ago in reply to gilshultz
    Thanks for the help. I think I could try control the primary voltage since the crossatron seems hard to find.
