Legacy Personal Blogs Help with high volt transistor
  • Date Created: 25 Feb 2015 7:25 PM Date Created
  • Views 1216 views
  • Comments 7 comments
  • amplifiers
  • transistors
  • electronics
  • power
  • solid_state
e14 Contributor
e14 Contributor
25 Feb 2015
Hello,
I am trying to find a transistor or amplifier that can work with large voltages, like 100 kilovolts. I am trying to build an x-ray machine and need the transistor to vary the voltages with an Arduino. The transistor will separate the Arduino from the high voltages.
Is there a place I could find that kind of transistor or amplifier? Ideas or options that are alternative approach to my problem are welcome.
    jw0752 over 11 years ago +1
    Hi Eddy, There are 2 things to control with respect to x-ray tubes. The high voltage will control the energy of the x-rays that are produced. Higher voltage produces a shorter wave length higher energy…
    e14 Contributor over 11 years ago in reply to michaelkellett
    Liked the article. I'll refer the diagram for my project.
    e14 Contributor over 11 years ago in reply to jw0752
    Thanks for your input. Is of great help.
    Hi Eddy, There are 2 things to control with respect to x-ray tubes. The high voltage will control the energy of the x-rays that are produced. Higher voltage produces a shorter wave length higher energy x-ray. The current to the x-ray tube's filament will control the mA of the x-ray tube and density (brightness) of the x-ray beam. All of the commercial x-rays I have ever seen control the kVp with a variac or other control of the lower voltage that generates the high voltage. The mA control is always on the current that heats the x-ray tube's heater for the cathode. More heat = more free electrons.
    Note: This type of project can be dangerous electrically and also from exposure to harmful radiation. If you need x-rays for a real reason it might be better to use an old x-ray head that has the proper shielding and collimation. Statistically exposure to x-rays increases your chance of developing cancer.
  • michaelkellett
    michaelkellett over 11 years ago
    Some time ago
    Linas Karpavicius
    posted an article about building  a power supply for an X-Ray machine on E14.
    I suggest you read it because it gives you some insights about working with high voltages.
    Just search for X-Ray on E14
    MK
  • Capper
    Capper over 11 years ago
    I have an extra hydrogen Thyratron I'll sell you.
