Legacy Personal Blogs Hercules LaunchPad and GaN FETs - Part 3b: BoosterPack Layout - my version
  • Date Created: 29 Oct 2016 3:27 PM Date Created
  • Views 2901 views
  • Comments 8 comments
  • kicad
  • smart_instrument
  • boosterpack
  • seeed
  • pcb_layout
  • texas_instruments
  • gan
29 Oct 2016
I'm designing a BoosterPack to evaluate GaN devices with the help of a microcontroller.
This double post (a+b) documents the PCB layout, specific for significant currency and high switching frequency.
The Schematic
The EVM User Guide has the schematics for this board. I removed the discrete deadband generator and bias voltage provider.
The deadband generator is replaced by a connection to Hercules LaunchXLII PWM outputs. The bias will come from that same LaunchPad's 5V power.
Here's my version. No bias or deadband circuit.
I've added a quadrature encoder. This part, connected to the Hercules eQEP module, is optional.
The PCB
Except for the changes mentioned above, I tried to stay as close as possible to the TI reference design.
There are several reasons for that:
  • budget: the PCB and GaN devices are expensive. I don't want to have to redo the work (ballpark figure: I loose more than 250 € on PCB and BOM for 3 boards, if I screw up. If you want me to be a hero, then send monies please).
  • I don't have anything close to the proper lab equipment to validate all aspects of the circuit's behaviour.
  • My "high switching frequency, high current" PCB layout skills are mediocre at best.
I am a little bit shaken by the cost of a four layer board. If you include shipping, I have a slightly cheaper quote for 3 OSHPark PCBs than for 5 Seeed PCBs with ENIG finish - if you include shipping costs.
A $10 coupon that I kindly got from michaelwylie tipped the balance, so I ordered at Seeed.
Here is my layout. You can compare it with TI's reference design images in my previous post.
Board Top (copper, mask, silkscreen, forgot to show the drill holes - see the image in the intro section above for those image)
White annotations are not part of the PCB design. I've added those on the blog image for clarity (and because jc2048 requested it image ).
Middle Top layer
Middle Bottom layer
Board Bottom + copper, mask, silkscreen and drills
I've attached the KiCAD design to this post.
(edit: updated to v 1.1, C30, P2, P3 wrong footprint)
In the next post, I'll review the custom schematic and footprint components that I've created for this design - and upload their libs.
Related Blogs
Hercules LaunchPad and GaN FETs - Part 1: Control Big Power with a Flimsy Mouse Scroll Wheel
Hercules LaunchPad and GaN FETs - Part 2: Make a BoosterPack
Hercules LaunchPad and GaN FETs - Part 3a: BoosterPack Layout - Reference Design
Hercules LaunchPad and GaN FETs - Side Note A: BoosterPack Layout - Custom KiCad Parts
Hercules LaunchPad and GaN FETs - Side Note B: Look at the PCB
Rotary Encoders - Part 1: Electronics
Checking Out GaN Half-Bridge Power Stage: Texas Instruments LMG5200 - Part 1: Preview
Rotary Encoders - Part 4: Capturing Input on a Texas Instruments Hercules LaunchPad with eQEP
Vintage Turntable repair: Can I fix a Perpetuum Ebner from 1958 - part 4 - Hercules LaunchPad Enhanced PWM try-out
imageLMG5200_HERCULES_LAUNCHXL2_BOOSTERPACK.pdf
LMG5200_HERCULES_LAUNCHXL2_BOOSTERPACK_v1_1.zip
    Jan Cumps over 10 years ago +2
    BOM: lplpC21, C15, C1630.1uFCAP, CERM, 0.1uF, 100V, +/-10%, X7R, 06030603GRM188R72A104KA35DMuRataC13, C20, C1931uFCAP, CERM, 1uF, 100V, +/-20%, X7R, 12061206C3216X7R2A105M160AATDKC8, C14210uFCAP, CERM…
    dougw over 10 years ago +1
    Nicely detailed blog. I'm looking forward to the big reveal....
    Jan Cumps over 9 years ago in reply to Jan Cumps +1
    Boards arrived:
    BOM:
    lplpC21, C15, C1630.1uFCAP, CERM, 0.1uF, 100V, +/-10%, X7R, 06030603GRM188R72A104KA35DMuRataC13, C20, C1931uFCAP, CERM, 1uF, 100V, +/-20%, X7R, 12061206C3216X7R2A105M160AATDKC8, C14210uFCAP, CERM, 10uF, 100V, +/-20%, X7S, 22202220C5750X7S2A106MTDKC9, C10, C11, C12, C17, C1862.2uFCAP, CERM, 2.2uF, 100V, +/-10%, X7R, 12101210GRM32ER72A225KA35LMuRataC27, C26222uFCAP, CERM, 22uF, 25V, +/-10%, X5R, 12101210GRM32ER61E226KE15LMuRataC2812.2uFCAP, CERM, 2.2uF, 16V, +/-10%, X7R, 08050805C2012X7R1C225KTDKC29, C30, C24, C25, C23547uFCAP, CERM, 47uF, 25V, +/-20%, X5R, 12061206C3216X5R1E476M160ACTDKC1, C3210pFCAP, CERM, 10pF, 50V, +/-5%, C0G/NP0, 04020402GRM1555C1H100JA01DMuRataC2210.1uFCAP, CERM, 0.1uF, 10V, +/-10%, X5R, 04020402C1005X5R1A104KTDKC41100pFCAP, CERM, 100pF, 25V, +/-10%, X7R, 0603060306033C101KAT2AAVXC5, C222.2uFCAP, CERM, 2.2uF, 10V, +/-10%, X7R, 06030603GRM188R71A225KE15DMuRataD2, D11GreenLED, Green, SMDLED_0805LTST-C170KGKTLite-OnP2, P32Terminal Block, 2x1, 5.08mm, TH10.16x15.2x9mm282841-2TE ConnectivityL114.7uHInductor, Shielded, Composite, 4.7uH, 10.5A, 8.89 ohm, SMD8.1 x 8 x 8.6mmXAL8080-472MECoilcraftR511.0kRES, 1.0k ohm, 5%, 0.1W, 06030603CRCW06031K00JNEAVishay-DaleR3120kRES, 20k ohm, 5%, 0.25W, 12061206CRCW120620K0JNEAVishay-DaleR410RES, 0 ohm, 5%, 0.1W, 06030603CRCW06030000Z0EAVishay-DaleU11LM5200AMOF, MOF0009AMOF0009ALM5200AMOFTexas InstrumentsR1, R22RES, 10.0k ohm, 1%, 0.063W,06030603JP1, JP22P11SW11Quadrature encoder, service mount EVQVVEVQ-VVD00203BPanasonicC6, C72CAP, CERM, 100pF, 25V, +/-10%, X7R, 0603060306033C101KAT2ATEST1 – 55nothingPCB1PCB LMG5200_HERCULES_LAUNCHXL2_BOOSTERPACK.kicad_pcbLMG5200_HERCULES_LAUNCHXL2_BOOSTERPACK.kicad_pcb
    Edit: costs for 3 complete boards
    parts I had to buy: 85 €
    pcb (includes $10 voucher): 65 €
    subtotal (what I spent): 150 €
    parts I received as samples: 50 €
    total for 3: 200 €
    per board: 67 €
    Additional:
    1 LabVIEW Home Edition license: 38.25€
    BOM:
    total for 3: 200 €
    per board: 67 €
    Additional:
    Jan Cumps over 10 years ago in reply to Jan Cumps
    Just got a message that my parts are in the FedEX truck. Of course I'm not at home image.
    It should include everything except 3* C29, C30, C24, C25, C23: CAP, CERM 47 µF, 25 V, 1206, X5R, 20%
    heads-up:
    I received an end-of-life notification (Not Recommended for New Designs) for this BOM element:
