Legacy Personal Blogs How Many Tools Does it Take To ....... Remove a screw from the wall
  • Author Author: dubbie
  • Date Created: 29 Aug 2020 12:11 PM Date Created
  • Views 3216 views
  • Comments 20 comments
  • tools
dubbie
dubbie
29 Aug 2020
I've always known that it takes many more tools than you think to do even the simplest of jobs and today I was able to confirm that. One of my bedrooms is being redecorated and this involved removing some box shelve units, which in itself was very straight forward, but it did leave the screws still fixed into the wall. I think the shelves were put up some 20 years ago so have had plenty of time to fuse into place. Additionally, they were also unusual screws as they were much longer than expected, being 5 cm long. Fortunately they were crosshead and I managed to remove 3 of the four using basically brute strength. How I put them in I cannot imagine - I must have been much stronger 20 years ago.
For the last screw every cross head screwdriver I used wasn't good enough and I ended up stripping the screw head. So, I used a junior hacksaw to cut a slot, then a standard hacksaw to make the slot wide enough for a flat blade screwdriver and eventually managed to remove the screw. The tools I used are shown below - and I used them all (except the hammer)! Plus a step ladder.
So from top to bottom:
1) Junior hacksaw.
2) Large pliers (a gift from Element14 - thanks very much) Tried to use these to rotate the screw - they didn't work.
3) Small pliers (for trying to remove the wall plug - didn't work)
4) Small wooden handles flat blade screwdriver (Not big enough)
5) Ratchet screwdriver flat blade (Not big enough)
6) Large wooden handled screwdriver flat blade (Finally did the job once a slot was cut into the screw head)
7) Rubber handled flat blade screwdriver (a gift from Element14 - thanks very much) Just not big enough.
8) Ratchet screwdriver cross head. (Worked for three of the screws just not for the last one)
9) Standard hacksaw.
10 Drill bits for drilling out the wall plug.
11) Set of screwdriver bits (Used with tool 8.)
12) Hammer (Actually I don't think I did use this)
13) Cordless drill (Used to remove the wall plug - mostly)
14) Step ladder (Not shown.)
So I had to use 13 tools (I haven't counted the hammer) to remove one screw from the wall, along with it's accompanying wall plug.
Below is the hole I ended up with. Parts of the wall plug are still inside this hole but I thought this hole is big enough as it is so I stopped.
I was surprised at how many tools I did need for this seemingly simple task.
Dubbie
    jw0752 over 6 years ago +5
    I like jobs like this they present a challenge. I also like to buy new and special tools so a tough job often gives me a pretext to add a new member to my arsenal of tools. I have often used a vise-grip…
  • Andrew J
    Andrew J over 6 years ago +5
    This would be a lot more believable if there was a can of WD-40 on the table
    beacon_dave over 6 years ago +5
    I don't see the 48" stilson pipe wrench or the hydraulic ram though ? Must be a small job...
    dubbie over 6 years ago in reply to colporteur
    Dave,
    That was the biggest hole, mainly because it was the first and I didn't knnow what I was doing. The other seven are much smaller. The rest of the plaster is still in quite good condition.
    I did make several trips downstairs to the garage to get tools as I would get one tool, that wouldn't work so I thought of another tool, so I'd get that one. That didn't work, so I'd think of another tool and go and get that one, and so n, and so on.....
    There were no beers that day - I was just pleased to be finished.
    Dubbie
  • Fred27
    Fred27 over 6 years ago
    I've also been doing some decorating today. There were loads of rawlplugs to remove because the previous owner thought it was OK to just wallpaper over them! I found that this hook and claw hammer do the best job for removing rawlplugs. Just screw in the hook (with a slightly undersized screw thread) and use a claw hammer to pull the plug out. I like the pliers for stubborn screws too. Note the grooves at the tip of the jaws which are aligned to make grabbing a screw head and twisting easy.
    When it come to filling, this is by far the best filler I've found. You can fill even large deep holes or cracks and it doesn't shrink. I has a nice grainy texture and it sands and paints easily.
    • Vote Up +5 Vote Down
  • kmikemoo
    kmikemoo over 6 years ago
    I think your count is really 17 because you're still missing the putty knife for the filler compound to fill the hole, the sandpaper and sponge to smooth the filler and the paint brush to hide it all.
    For me, it would have been vice grips early, rip off the head, pound it in with the hammer, wind up making a bigger hole and spend three days trying to hide it all with filler compound.
    beacon_dave over 6 years ago in reply to dubbie
    Now this sounds like a job for a decorating robot...
    I have encountered a similar problem here in that the previous owner scored the plaster before wallpapering. Unfortunately two coats of filler basecoat hasn't managed to smooth it over enough.
  • colporteur
    colporteur over 6 years ago
    I think the operation might qualify you for a surgeons certificate.
    I noticed the picture of the hole is rather small, can you confirm the rest of the wall is intact and you didn't come at the problem from the opposite end and the hole a 12 inches of dry wall is all that remains. You know pictures can be deceivingimage
    Hopefully you didn't have to travel three flights of stairs to the van to get each tools. If yes, then you get two beers instead of just one for a job completed. Got to keep you fluid levels up.
