Legacy Personal Blogs How to set up a laser printer?
  • Date Created: 17 Jan 2015 3:22 PM Date Created
  • Views 826 views
  • printer
  • to
  • up
  • how
  • a
  • laser
  • set
e14 Contributor
e14 Contributor
17 Jan 2015
I am new on Raspberry pie, I would like to print any document but I have to idea how to set up a printer. I am using a network printer  for my computers already in used. How to I start with the Raspberry?
  • clem57
    clem57 over 11 years ago
    Some suggestions if you run Raspian:
    You should probably install:
    cupsys (cups itself, the server that receives print jobs)
    cupsys-bsd (cups version of bsd print command like lpr)
    cupsys-client (cups print commands, "lp" and others)
    Install CUPS (the cupsys package) and then the foomatic-bin and
    foomatic-db packages, the most complete printer driver database and
    helpers. Follow their docs and manpages, they are very easy to follow,
    and luckily with a single command line your printer will be set up.
    Hope this helps,
    Clem
  • clem57
    Hope this helps,
    Clem
