Legacy Personal Blogs ImageCraft JumpStart Microbox Education Kit - Part 1: Preview
  • Date Created: 18 Oct 2015 10:05 AM Date Created
  • Views 3424 views
  • Comments 18 comments
  • educational
  • firmware
  • sama5d4
  • imagecraft
  • embedded
  • arm_cortex
  • stm32
  • stmicro
  • kit
  • nucleo
18 Oct 2015
The ImageCraft JumpStart Microbox Education Kit is a set of hardware and software tools to teach C and Cortex-M embedded programming.
In essence, it's an Arduino compatible shield, an STMicro Nucleo dev board, a C book, an IDE, a compiler and libraries.
In this blog series I'm trying to find out if it's more then just an existing 3rd party dev board paired with a shield. And if (and how) this kit can turn you into an embedded programmer.
This video is unavailable.
In part 1, I'm checking the out-of-box experience. Is it easy to get the boards and tool chain running?
Spoiler Alert: it's easy
Getting Started Fast
We all know what it's like to unpack a new development board, and then struggle for hours, days, weeks (hello, sama5d4, I'm looking at you).
That's not the case with this board. The Quick Start Guide walks you through software and hardware setup. Step by step, as it should be.
When completed, you have the drivers installed, the IDE up and running and the tool chain configured.
Compiling and running the first example works straight away. The OLED display was showing 'Hello World' without any issue. Perfect experience.
I tested 6 of the examples, and they all work flawlessly. The build cycle is fast.
The only thing I struggled with a little (and the quickstart guide warns you for that) is mounting the shield on the ST Nucleo board. The shield uses stacking headers, with springy sharp pins.
It's a bit tough to properly align the shield with the dev board.
With proper care, this works, though.
Food for thought
I don't know at this moment,after doing the quickstart, what the competitive advantage of this kit is going to be.
It's running on multiple legs. It tries to learn standard C, and also embedded C for a particular controller family.
The IDE is not one you'd usually see in your common professional environment.
it comes with an own compiler and abstraction libraries - is that going to be useful for a future firmware developer? Would a professional company choose this combination as its strategic firmware development base?
Is there an educational advantage in supporting an in-house compiler?
Why does one spend effort in designing and maintaining bespoke libraries and tool chains if the goal is education? Is there a part of ImageCraft's business model that I don't understand yet?
I don't have the answers to those questions yet. But if the training track is as smooth as the out-of-box experience, I have high hopes.
Hang on for part 2...
Related posts
ImageCraft JumpStart Microbox Education Kit - Part 2: Stepping Through an Example - what do I learn?
ImageCraft JumpStart Microbox Education Kit - Part 3a: The Education Shield - LED matrix and I/O expander
  • sidprice
    sidprice over 10 years ago +1
    Hi, I am the developer of the Jumpstart debugger that is a part of the Jumpstart Microbox kit and also I am a longtime AVR programmer. The main reason I never switched to the Cortex MCUs is simple, the…
    shabaz over 10 years ago +1
    Hi Jan, It will be great to hear what you make of it. All too often some of the technical benefits get lost in the product website / datasheet. I found the comparison with GCC on the website rather odd…
    shabaz over 10 years ago in reply to richardman +1
    Hi Richard, I'll check out the latest site, just fyi the URL I'm using is in the screenshot below (the page has a 17th Sep date), and I did Ctrl-F5 to force a reload, this URL may need redirecting if this…
    DAB over 10 years ago
    Nice post Jan,
    I agree, if your project is aimed at learning C and controlling an Arduino type processor, then they should have either used the standard IDE and included the code headers to run their board or made a duplicate so that the users can advance beyond the kit.
    Nice post Jan,
    shabaz over 10 years ago in reply to DAB
    I also agree with the astute observations in the "Food for thought" section.
    The compiler and tools does look easy to use. But is the hurdle really as hard as it's made out, to use alternative tools?
    For example, what is the difficulty involved in using an ARM microcontroller - are the manufacturers not
    providing an API or example code that is not easy to follow? (Not a rhetorical question - a genuine one).
    And by using the Jumpstart compiler and API, what are the disadvantages? We see some comments (such as the one in
    the screenshot below) that indicate some reasons to do with this compiler and kit, but I'm curious how hard-to-use the free tools
    are for hobbyists, since this Imagecraft compiler (Non-commercial, Educational Licence) costs $$$$ compared to free.
    Basically the free tools may be harder to use, but (a) are they hard enough to be worth spending $99, and (b)
    what will be lost by not using the free tools (such as the (possible) benefit that other users on forums will be more familiar with
    the compiler and API supplied by the manufacturer, in case people need support on forums).
