Legacy Personal Blogs Intel Edison - First Look (and first light)
  • Author Author: rsc
  • Date Created: 4 Feb 2017 4:19 PM Date Created
  • Views 813 views
  • intel edison
rsc
rsc
4 Feb 2017
Here it is!image
I'm not very patient................[tap tap taping fingers on the table]
OK, after two hours of installing software, reflashing the Edison board firmware and re-installing Arduino 1.8 with Edison core libraries............
Ta Da.......I've managed to blink the LED!
It's the simple things in life..............that make it all worth while.........
Next we'll try and talk to some Arduino shields.
  • clem57
    clem57 over 9 years ago
    As I tried and failed, Can you go through the steps? Maybe it will help others like me.
  • clem57
  • rsc
    rsc over 9 years ago in reply to clem57
    After downloading all the manuals and examples I could find on instructables and element14, I just followed all the instructions on
    https://software.intel.com/en-us/get-started-edison-windows
    I had to find a couple of cables and a power supply
    Then I assembled the board
    https://software.intel.com/en-us/get-started-edison-windows-step1
    https://software.intel.com/en-us/node/628221
    I set up the board in device mode
    https://software.intel.com/en-us/node/628222
    Then I ran the setup tool
    Using the installer for windows 64bit
    https://software.intel.com/iot/hardware/edison/downloads
    After installing the USB driver and flashing the new firmware I picked the Arduino User interface
    https://software.intel.com/en-us/get-started-edison-windows-step3
    https://software.intel.com/en-us/intel-edison-board-user-guide
    At this point I tried to run an Arduino sketch, but there wasn't a board manager in Arduino 1.6,
    So I had to download and install Arduino 1.8 and then install the intel edison core libraries.
    After that, I was able to run the Blinky example on the edison board.
