Legacy Personal Blogs LaserCutter Testfile - For K40 Laser
  • Author Author: mayermakes
  • Date Created: 22 Apr 2019 12:25 PM Date Created
  • Views 11070 views
  • k40whisperer
  • diy laser
  • help
  • engraving
  • testfuile
  • lasercutter
  • material
  • How To
  • laser cutter
  • scrochworks
  • element14presents
  • tools
  • laser cut
  • materialtest
  • k40
  • settings
  • stencil
  • laser
  • laser engraving
  • mayermakes
  • laser cutting
mayermakes
mayermakes
22 Apr 2019
I recently got my K40 Laser to work and designed a testfile to tune it in for different materials.
The File is compatible with K40 Whisperer by Scorchworks. You have to manually dial in the values while lasering to get the desired output.
There are 3 steps you have to follow while using it:
1.
Raster engrave starting with 20%
increase the Laser power as the Rastering progresses according to the writing on the file
2. Vector engrave starting with 20%
increase the Laser power as the engraving progresses according to the writing on the file
3. Vector cut
increase the Laser power as the cutting progresses according to the writing on the file
Keep in mind that the outer contour will be cut at the end, you might want to dial back the power depending on the material/results you saw while perfomring this test.
for 4mm Playwood I ended up with dialing back to 30%.
You goal is always to get a perpendicular cut with the minimum amount of power. the engraving settings are mostly based on looks and desired depth /color.
Feel Free to use this File as you wish
CC-BY-SA mayermakes
See you in another element14presents Video!
Clemimage
Materialtest.svg.zip
  • ralphjy
    ralphjy over 7 years ago +2
    Hi Clemens, I was wondering what program you use to generate the SVG file. The MakerSpace at our local community college uses Adobe Illustrator but I am thinking of using InkScape. Are you generating the…
  • mayermakes
    mayermakes over 7 years ago in reply to ralphjy +1
    I use Inkscape. You can suitable files with any vector graphic program. Just keep in mind that you have to use the pure colors (255 red fro cut, 255 blue for engrave and 255 black for raster engrave, …
  • ralphjy
    Hi Clemens,
    I was wondering what program you use to generate the SVG file.  The MakerSpace at our local community college uses Adobe Illustrator but I am thinking of using InkScape.  Are you generating the file directly in K40 Whisperer?
    Ralph
  • ralphjy
    Hi Clemens,
    Ralph
  • mayermakes
    I use Inkscape. You can suitable files with any vector graphic program. Just keep in mind that you have to use the  pure colors (255 red fro cut, 255 blue for engrave and 255 black for raster engrave, (0 an all other values).
    It is also noteworthy that you should resize the canvas to the size of your finished design, this will reduce loading times in k40whisperer.
