      • Japan
      • Vietnam
Legacy Personal Blogs Little Blue Man Dances Again
  • Author Author: three-phase
  • Date Created: 1 Jul 2019 8:31 PM Date Created
  • Views 1388 views
  • Likes 14 likes
  • Comments 7 comments
  • blue man
  • broken arm
  • gorilla glue
three-phase
three-phase
1 Jul 2019
A few days ago, I received a swag bag from Tariq and unfortunately as reported, the little blue man within had been roughed up a little and had to be hospitalised with a broken arm.
You will all be pleased to know, that with the help of some gorilla glue, blue man is back on the road to full recovery. I managed to ease the twisted shoulder back into position without it snapping off and applied a little glue.
I tried in vain to get the spring to sit in the joint and slide into position to allow the pin to be inserted. The spring was twisted which didn't help. Every attempt resulted in the spring flying out and a hunt initiated to try and find it.
In the end I glued the end of the spring into the arm and then I could get it back into the joint by holding the other end of the spring with some tweezers.
Little blue man is now recuperating ready for an appearance in a future blog or two.
  • Fred27
    Fred27 over 6 years ago +10
    It's surprising how much effort we sometimes put in to fix something broken. I once did some serious shoulder surgery on a Playmobil figure my son particularly liked. It involved sub-mm drills and pins…
    genebren over 6 years ago +8
    Donald, Very nice repair job on your little blue man (too bad he was injured on his way to you). Kudos on having the sticktoitiveness ( ) to persevere in this healing/repair procedure. I am sure all of…
  • neilk
    neilk over 6 years ago +4
    Well done, Donald. Gorilla glue is magic! Neil
    Donald,
    Very nice repair job on your little blue man (too bad he was injured on his way to you).  Kudos on having the sticktoitiveness (image) to persevere in this healing/repair procedure.  I am sure all of the little blue men out there see you as the true hero that you are.
    Gene
    • Vote Up +8 Vote Down
  • three-phase
    three-phase over 6 years ago in reply to genebren
    Many thanks Gene.
  • three-phase
    Many thanks Gene.
