Legacy Personal Blogs LM386 Audio Amplifier
  • Author Author: mrchunckuee
  • Date Created: 13 Feb 2016 4:14 AM Date Created
  • Views 3664 views
  • Comments 11 comments
  • audio amplifier
  • lm386
  • lm386 audio amplifier
mrchunckuee
mrchunckuee
13 Feb 2016
Greetings! My first post on Element, is a small audio amplifier using LM386 integrated.
For the design has been based on the one proposed in the datasheet (Gain = 200), some components and filters are added to the feed inlet (VALIM = 12V), the circuit used is this:
Here more photos of the PCB:
buttom pcb
The final PCB with all componences looks like this:
Here one video of the circuit in action (video in spanish):
See more projects or info in my blog (in spanish)
    jw0752 over 10 years ago +2
    Hi Pedro, This was a very nice project. It is really good that you are open to learning. I have learned a lot of new things by listening to michaelkellett as he always has good solid advice. John
  • jc2048
    jc2048 over 10 years ago in reply to DAB +2
    Page 4 of the datasheet has a graph of Voltage Gain vs Frequency. That shows about 40kHz for the IC itself with a gain of 200 (C pin1 to pin8 = 10uF). Out of curiousity, I tried simulating the input network…
  • nick123
    nick123 over 10 years ago +1
    Welcome, cool amp, see if you can get a guitar amplified through there
    DAB over 10 years ago
    What is the bandwidth for the amplifier?
    Hi Pedro,
  • mrchunckuee
    mrchunckuee over 10 years ago in reply to michaelkellett
    Thanks for the recommendations are useful for future designs
  • michaelkellett
    michaelkellett over 10 years ago
    if you do any more of this work the consider how to arrange the tracks so that the ground plane flows better. Look how far it is from VALIM-2 to X1-2 and how thin the ground connection gets at the top of the board. The ground connections to the pot have to share a long and tortuous path with the load current. The little bit of ground near C7 isn't doing anything useful.
    For  a low gain audio amp you may get away with this (although it might well have issues with CE level EMC susceptibility tests). For anything working at high frequencies it pays to make your ground planes better.
    Hope this helps your next design.
    MK
  • mrchunckuee
    mrchunckuee over 10 years ago in reply to nick123
    Thanks! I haven't experimented with guitar amplifiers, but if i find something i share
