Legacy Personal Blogs MODBUS master in my cell phone
  • Author Author: gihu
  • Date Created: 5 Aug 2013 5:33 PM Date Created
  • Views 3184 views
  • Comments 13 comments
  • android
  • bluetooth
  • seral
  • port
  • profile
  • spp
  • modbus
  • rtu
gihu
gihu
5 Aug 2013
In this post I would like to show the community a project I started last summer:
The goal:
    •   Read an 8 analog input MODBUS RTU module with an android phone.
Motivations:
    • Learn about MODBUS.
    • Build my first android app (after the “hello world”).
    • Learn about Bluetooth technology.
This project is based in the use of the serial port profile (SPP) to enable an Android phone to manage a MODBUS net. I had tried the lairdtech BTM443, but in the end I used the RN-42 because it has the RN42XV version which makes it easier to handle it in prototypes.
A little hardware
A little hardware to supply the module and to drive the TTL signals to RS485 for the MODBUS RTU physical layer is needed.
M8EA
This is the 8 analog input module, manufactured by Ibercomp. Instead of sensors I have used potentiometers, and I have configured the module as 0V~2.5V input.
Android app
I have used Eclipse IDE with ADT, SDK tools, and the example and indicatios from http://developer.android.com/index.html
The modbus protocol is implemented in the app, there are lots of C examples on the web.
After many hours searching information, reading and studying examples and datasheets, burn-out some components..., typing code, checking and sniffing the communications, and making lots of mistakes... I succeed.
I hope you like the result, and it can give some ideas to you all, or inspire new hobbyist projects.
Above one picture of the set up and the video of the app working.
I really hope you like this post.
    shabaz over 10 years ago in reply to Sisteck +1
    You both need to follow each other as I understand, even if just one person wants to send a private message. Code can be shared by attaching to the post, or perhaps use a service like github (assuming…
  • gihu
    gihu over 10 years ago in reply to shabaz +1
    Thanks shabaz
  • Sisteck
    Sisteck over 10 years ago
    Hello,
    I'm starting now with Android and I would like to build a Master MODBUS RTU
    Can you share me your code?
    Thank you
  • gihu
    gihu over 10 years ago in reply to Sisteck
    Hi Dino,
    Please send a private message with your email address.
    It it was my first app, so it is like a little frankenstein's monster build of pieces from other examples and projects...
    Have you decided the physical comms you will use? Which modbus slaves will you use?
    Regards,
    Miguel
  • Sisteck
    Sisteck over 10 years ago in reply to gihu
    Hi gihu,
    I can not send you a private message, I do not know why maybe you need to enable me ...
    however, you can use this email (spam I do not care, it's not my official image
    cusna at hotmail dot com
    In order to Modbus in the android, I use of slave custom, where I built both hardware and software,use Microchip controller.
  • Sisteck
    Hi gihu,
    I continue to be unable to send you private messages image
  • gihu
    Let me check.
    I will try to send you a message.
  • gihu
    Let me check.
  • Sisteck
    This is what appears when I try to send a private message
    Cannot send direct messages to users you're not connected to.
    Code can be shared by attaching to the post, or perhaps use a service like github (assuming you two are sharing stuff you don't mind others to benefit from too).
  • gihu
    Me too
  • gihu
    Thanks shabaz
