Legacy Personal Blogs MODBUS master in my cell phone
  • Author Author: gihu
  • Date Created: 5 Aug 2013 5:33 PM Date Created
  • Views 3190 views
  • Comments 13 comments
  • android
  • bluetooth
  • seral
  • port
  • profile
  • spp
  • modbus
  • rtu
gihu
gihu
5 Aug 2013
In this post I would like to show the community a project I started last summer:
The goal:
    •   Read an 8 analog input MODBUS RTU module with an android phone.
Motivations:
    • Learn about MODBUS.
    • Build my first android app (after the “hello world”).
    • Learn about Bluetooth technology.
This project is based in the use of the serial port profile (SPP) to enable an Android phone to manage a MODBUS net. I had tried the lairdtech BTM443, but in the end I used the RN-42 because it has the RN42XV version which makes it easier to handle it in prototypes.
A little hardware
A little hardware to supply the module and to drive the TTL signals to RS485 for the MODBUS RTU physical layer is needed.
M8EA
This is the 8 analog input module, manufactured by Ibercomp. Instead of sensors I have used potentiometers, and I have configured the module as 0V~2.5V input.
Android app
I have used Eclipse IDE with ADT, SDK tools, and the example and indicatios from http://developer.android.com/index.html
The modbus protocol is implemented in the app, there are lots of C examples on the web.
After many hours searching information, reading and studying examples and datasheets, burn-out some components..., typing code, checking and sniffing the communications, and making lots of mistakes... I succeed.
I hope you like the result, and it can give some ideas to you all, or inspire new hobbyist projects.
Above one picture of the set up and the video of the app working.
I really hope you like this post.
    shabaz over 10 years ago in reply to Sisteck +1
    You both need to follow each other as I understand, even if just one person wants to send a private message. Code can be shared by attaching to the post, or perhaps use a service like github (assuming…
  • gihu
    gihu over 10 years ago in reply to shabaz +1
    Thanks shabaz
  • Sisteck
    Sisteck over 10 years ago
    Hello,
    I'm starting now with Android and I would like to build a Master MODBUS RTU
    Can you share me your code?
    Thank you
  • gihu
    gihu over 10 years ago in reply to Sisteck
    I bought a new PC, so I have to look if I have copy of the code. I used eclipse, now I recommend you to use Android Studio.
    The serial comms were over bluetooth (SPP). Maybe now it is easier to use a FTDI to 485 cable and make the serial comms over USB.
    I contact you as soon as I check the old PC.
  • gihu
