Legacy Personal Blogs MODBUS master in my cell phone
  • Author Author: gihu
  • Date Created: 5 Aug 2013 5:33 PM Date Created
  • Views 3193 views
  • Comments 13 comments
  • android
  • bluetooth
  • seral
  • port
  • profile
  • spp
  • modbus
  • rtu
gihu
gihu
5 Aug 2013
In this post I would like to show the community a project I started last summer:
The goal:
    •   Read an 8 analog input MODBUS RTU module with an android phone.
Motivations:
    • Learn about MODBUS.
    • Build my first android app (after the “hello world”).
    • Learn about Bluetooth technology.
This project is based in the use of the serial port profile (SPP) to enable an Android phone to manage a MODBUS net. I had tried the lairdtech BTM443, but in the end I used the RN-42 because it has the RN42XV version which makes it easier to handle it in prototypes.
A little hardware
A little hardware to supply the module and to drive the TTL signals to RS485 for the MODBUS RTU physical layer is needed.
M8EA
This is the 8 analog input module, manufactured by Ibercomp. Instead of sensors I have used potentiometers, and I have configured the module as 0V~2.5V input.
Android app
I have used Eclipse IDE with ADT, SDK tools, and the example and indicatios from http://developer.android.com/index.html
The modbus protocol is implemented in the app, there are lots of C examples on the web.
After many hours searching information, reading and studying examples and datasheets, burn-out some components..., typing code, checking and sniffing the communications, and making lots of mistakes... I succeed.
I hope you like the result, and it can give some ideas to you all, or inspire new hobbyist projects.
Above one picture of the set up and the video of the app working.
I really hope you like this post.
    shabaz over 10 years ago in reply to Sisteck +1
    You both need to follow each other as I understand, even if just one person wants to send a private message. Code can be shared by attaching to the post, or perhaps use a service like github (assuming…
  • gihu
    gihu over 10 years ago in reply to shabaz +1
    Thanks shabaz
    I am interested in the bluetooth portion.
    Care to share?
  • gihu
    gihu over 13 years ago in reply to e14 Contributor
    Hi james,
    I can share you my code, but for the bluetooth conection I just use the 'BluetoothSerialService' and 'DeviceListActivity' classes from BlueTerm example. So I use bluetooth serial port profile just to emulate the physical layer of a MODBUS RTU, the code I wrote was for the datalink layer and aplication layer. So, about bluetooth connection there is no difference with Blueterm.
    I know you are in a hurry, I saw your comments in Cypress PSoC 4 Pioneer Kit. So I try to help you, first of all, you need to know the bluetooth profile(SPP, Headset, Health equipment,...) that use your remote equipment, if you try to connect with different profiles, conection cannot be stablished. Take into account, that depending the profile, you should use different minimum API level, for example you won't be able to create an app that uses BLE for Android 2.3.
    Try to know the profile of your remote equipment, or even check if you can search and connect with it from Settings/Bluetooth of your Android device.
    Let my know what you get by private message in we keep on this chat.
    Hope it helps,
    Miguel
    e14 Contributor over 13 years ago in reply to gihu
    Thanks for that.
    I am trying to outsource the project.
    'Plenty of better quicker programmers out there.
    BTW, this is what we are building.
    http://www.indiegogo.com/projects/nirvana-cruise-control/x/3289688
    Thanks for that.
