Legacy Personal Blogs My First Ever Crimping Experience
  • Author Author: dubbie
  • Date Created: 20 Nov 2020 2:54 PM Date Created
  • Views 6159 views
  • Likes 10 likes
  • Comments 34 comments
  • spade connections
  • crimping
dubbie
dubbie
20 Nov 2020
For my Sand Based Cat Detector (Cat Detector Using Sand #2 : The Implementation ) I used a lead acid battery with spade connections. I have never properly used spade connections before (I usually use crocodile clips or solder directly) so I thought this would be a good time to start as I am working my way towards an outdoor mobile robot and robust and reliable connections are essential. Not really knowing much about making spade or crimping connections I decide that the best approach would be to buy some and just try it out. I have wanted to crimp for some time so rather than find out about it I just blundered in and bought something. I do not expect to do much crimping in the future so just looked online and bought the cheapest set I could find that seemed to do what I wanted.
I used deep learning to update my natural neural networks in my head, basically I just stuck some wire inside the crimpets (or connectors) and tried to make good connections with the wire using the crimping tool. Initially there was little success as the tool I obtained did not come with any instructions what-so-ever. The crimpets would not stay on the wire while I attempted to use the crimping tool and several crimpets were harmed in this process.
It took me several attempts to work out that the tool I had purchased did not do any folding of the little tabs on the crimpets. Once I had worked this out and folded over the ;little tabs using some pin nosed pliers I was able to make some good crimped connections. I'm not sure if it uses cold-welding or just mechanical interference to make a good physical and electrical connection, but they seem to work, so all is good.
Dubbie
    shabaz over 5 years ago in reply to ajcc +8
    Hi Adrian, Probably everyone has their own recommendations, I've been quite impressed with the Multicomp HT-xxx range, I have several of them, they are about $25 ballpark. The HT-230 crimp tool HT-230…
    shabaz over 5 years ago +7
    Hi Dubbie, I do the same as Doug, i.e. add some solder (after crimping) if the specific crimp tool isn't suitable. However, I think maybe your tool might do both the bare wire crimping and the insulation…
    dougw over 5 years ago +5
    There is a lot of science behind good crimp connections. I suspect they rely on the wire bring more springy than the crimp terminal, so after a crimp there is always force on the joint Whenever I don't…
  • ajcc
    ajcc over 5 years ago in reply to shabaz
    Thanks for pointing out that they're for bare non-isolated terminals, I didn't even think about that. The Multicomp crimping tool looks like a very affordable and capable tool, at least those crimps looks nice image I've only ever heard good things about Knipex, often following a story about how many decades ago said tool was purchased.
    dubbie over 5 years ago in reply to colporteur
    Sean,
    I just tried to take a picture of one ofo the crimps I made. I think your camera must be much better than mine as I could not get a clear photograph - too bright and shiny or too blurred. Suffice to say I can do better now, but then I guess that is true of gaining experience of using most tools.
    Dubbie
    dubbie over 5 years ago in reply to shabaz
    Shabaz,
    Good crimping, mine look nothing like as good as these.
    Dubbie
    Shabaz,
    You were right. I tried out your approach and it worked fine - well, better anyway. I do still have to start the folding over process slightly with some pliers but after that it works well. Who would ever know! I have now wasted (make that experimented) with many more crimps now and I think I can just about make good crimps now. I do find the tool very weird to hold as no matter how I hold it, it always seems to be upside-down. It is also quite heavy so I wouldn't not want to use it much - but it does allow me to make very satisfying forces on small defenceless bits of metal.
    Dubbie
    dubbie over 5 years ago in reply to ajcc
    Adrian,
    Turns out my crimping tool does do more than just finish the crimp, it actually does some of the folding over as well. I do have to start the folding over process using pliers but only a little bit and then the tool does the rest. Who knew! That's what comes of a tool with no instructions what-so-ever.  I am now able to make even better crimps.
    Dubbie
