Legacy Personal Blogs My First Try Using The MagiQuest Wand With An Arduino
  • Date Created: 7 Feb 2015 3:49 AM Date Created
  • Views 4640 views
  • magiquest
  • wand
  • relay
e14 Contributor
e14 Contributor
7 Feb 2015
So I have been looking around online for ways to use the MagiQuest wand at home, but have found very few solutions. I decided to make my own. Using the Arduino IR library I got some raw values from the wand using a old IR sensor from a VCR and then took those values and converted them from decimal to hex value using an online calculator. I just googled it and found one. Then made up some code that detected when a certain IR code was detected to activate my relay board and turn some lights off and on. My hook up is the IR sensor is on a breadboard connected to the Arduino, then I have jumper cabled hooked into a IDE cable because I only have male to male jumpers, then the IDE cable hooks into the relay board activating the relays. Right now I have 3 wands that the Arduino can interact with I can add more though.
#include <IRremote.h>
int RECV_PIN = 3; //
int led1 = 5;
int led2 = 6;
int led3 = 9;
int itsONled[] = {0,0,0,0};
#define code1  //Place your IR codes here
#define code2
#define code3
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
  Serial.begin(9600);
  irrecv.enableIRIn();
  pinMode(led1, OUTPUT);
  pinMode(led3, OUTPUT);
void loop() {
  if (irrecv.decode(&results)) {
    unsigned int value = results.value;
    switch(value) {
       case code1:
         if(itsONled[1] == 1) {
            digitalWrite(led1, LOW);
            itsONled[1] = 0;
         } else {
             digitalWrite(led1, HIGH);
             itsONled[1] = 1;
          break;
       case code2:
         if(itsONled[2] == 1) {
            digitalWrite(led2, LOW);
            itsONled[2] = 0;
         } else {
             digitalWrite(led2, HIGH);
             itsONled[2] = 1;
          break;
       case code3:
         if(itsONled[3] == 1) {
            digitalWrite(led3, LOW);
            itsONled[3] = 0;
         } else {
             digitalWrite(led3, HIGH);
             itsONled[3] = 1;
          break;
    Serial.println(value);
    irrecv.resume();
  • mpflaga
    mpflaga over 11 years ago
    Congratulations. My family has been enjoying MagiQuest and the wands for years. My son had an amazing look of joy on his face one day when I told him that I had captured the magic and brought it home. Since non-hackers must leave the magic at Great Wolfe Lodge. Noting that you can often pickup additional wands on eBay. And of course the baby girl had to get a pink wand.
    To help in this venture I had successfully decoded the wands format into a fork of mpflaga/Arduino-IRremote as to uniquely identify each wands serial number and magnitude of swish (along with adding 2.5ch Helicopters, another project) and implement them into Arduino UNO's and Digispark's (ATtiny85) to create a Dueling MagiQuest Wand Game for Detroit's Maker Fair.
    Have Fun, hacking...
    e14 Contributor over 11 years ago in reply to mpflaga
    That sounds cool! I was actually thinking about trying to make some home appliances interconnected and activating them with a swoosh of my wand.
