Legacy Personal Blogs My New Robot
  • Author Author: dubbie
  • Date Created: 26 Mar 2019 1:29 PM Date Created
  • Views 3709 views
  • Likes 10 likes
  • Comments 23 comments
  • month or robots
  • robot
  • walking robot
My New Robot
dubbie
dubbie
26 Mar 2019
Just received my latest robot called Super Fighter, already assembled which is a change for me. I was attracted to this robot as it had a reasonable price, it looked good, it was supposed to walk (which it does - sort of), fire a 'laser', speak and most importantly, fires foam disks out the front.
It is quite an interesting design as most parts are independent of all others. The laser arm contains it's own motor and LED, the two legs have a motor in each foot, the head just contains LEDs and the infrared communications diodes and the foam disk mechanism fits into the chest. It would be relatively easy to add a motor to the second arm as this is not currently motorised, as well as adding sensors and what-knots to the head.
I have already disassembled it and it looks relatively easy to replace the existing controller board with an Arduino or similar. The supplied controller looks like it is some sort of custom single chip microprocessor and I doubt it could be reprogrammed. Most of the motors and LEDs seem to be driven directly from this custom PCB so if replaced it would be necessary to provide H bridge drivers or similar for three DC motors (two feet and one arm), plus transistors to drive the two motors used in the foam disk firing mechanism - these only rotate in one direction so do not need H bridge drivers.
There is some spare room inside the chest cavity for other sensors and radio communications. The current remote control system uses infrared. It might be necessary to remove the foam disk firing mechanism if more space were needed.
I wonder if I could use this for an entry into the Month of Robots competition?
Dubbie
  • ralphjy
    ralphjy over 7 years ago +8
    Looks like a fun toy. We should have a new competition for best toy hack.
  • fmilburn
    fmilburn over 7 years ago in reply to ralphjy +6
    tariq.ahmad great suggestion from Ralph
  • tariq.ahmad
    tariq.ahmad over 7 years ago in reply to ralphjy +6
    Have a special place in my heart for our first Project14 Techno Toys . Sounds similar to that, would be cool to have a similar competition.
  • ralphjy
    • Vote Up +8 Vote Down
  • tariq.ahmad
    • Vote Up +6 Vote Down
    dubbie over 7 years ago in reply to tariq.ahmad
    Tariq,
    This must have been before my time. I'm sure I would have been involved if I had known about it. I'll have to go back and look at all the stuff people did.
    Having another go and some similar type of hacking/expansion would be great.
    Dubbie
    • Vote Up +5 Vote Down
    Tariq,
    Dubbie
