Legacy Personal Blogs My Verilog Diary - 0 : Introduction
  • Author Author: msimon
  • Date Created: 1 Oct 2017 4:15 PM Date Created
  • Views 1357 views
  • Comments 8 comments
  • fpga
  • verilog
  • my_verilog_diary
msimon
msimon
1 Oct 2017
I want to improve my skills on FPGA design so I decided to cover Verilog/System Verilog from scratch. I believe one of the best methods of learning is teaching, therefore, I will have a diary of my progress. Hopefully, it will help other community members too.
What I have planned to do is start from the very beginning of Verilog to go deep topics as long as I go. Not only cover the syntax of the language but also mention digital design methods I need to implement that subject and FPGA implementation of the task. I know it is very time-consuming and there will be always something prevents me to write but I will do my best to write weekly posts.
I will be using Verilog HDL - A Guide to Digital Design and Synthesis written by Samir Palnitkar. I will be happy if you suggest books you like so learners can buy them.
Currently, I have DE0-Nano board (thanks to Element14 roadtest). I think it is sufficient for covering many subjects. If you have any suggestion I am happy to listen to you image
You can follow all the articles related to my verilog diary by searching my_verilog_diary or coming to this post. I will update this post if there is an update.
My Verilog Diary - 1: Modules and Ports
  • msimon
    msimon over 8 years ago in reply to djfraz +2
    Hi Duncan, Thanks for the recommendation. Michael also recommended that book. I will check that one and buy it. From programmer's perspective, HDL languages are strange. But, I can understand that because…
    DAB over 8 years ago +1
    Great idea, I look forward to your posts. If you do some searching, you will find a fair number of older HDL and VHDL tutorials and examples. HDL has a very long history. I remember numerous EE friends…
  • msimon
    msimon over 8 years ago in reply to DAB +1
    As you said there are aplenty of documents out on the internet. I will benefit them and share my experience here It won't be exactly the verilog tutorial. I can say it will be more like my verilog adventure…
  • jc2048
    jc2048 over 8 years ago
    That sounds interesting - look forward to reading your diary.
    Another good method of learning is by doing, so you'll have that one covered too.
    I can't recommend any Verilog books.
    The only VHDL book I've got is 'VHDL for Programmable Logic' by Kevin Skahill. It dates from 1996. All the examples use Cypress devices and design tools because he worked for them and wrote the book in company time. It seemed to work ok for me - I didn't have any trouble writing HDL for their devices [large CPLDs with memory blocks] and, later on, the VHDL skills were quite transferable for working with Xilinx FPGAs.
  • msimon
    msimon over 8 years ago in reply to jc2048
    Hi jc2048 ,
    Thanks for sharing your experience image You, are right doing is a great learning practice, I will try to implement projects on board as long as I can.
    Thanks for the VHDL suggestion. I think some books are written by vendors to increase their profitability but I think it is not a big problem. HDL is independent of vendor there are some vendor-specific tricks and EDA tools can be different but the main design is the same. Thanks for your suggestion there may be people who interested in VHDL rather than Verilog.
    Thanks,
    Mehmet
  • michaelkellett
    michaelkellett over 8 years ago in reply to msimon
    I had a quick Google for the book you are using and couldn't find any edition later than 2003.
    Which edition have you got ?
    The System Verilog standard was not released until 2009 so I doubt that any book published before 2011 on the subject is worth reading.
    I'm not a Verilog expert (I prefer VHDL) but I understand that there were significant changes between 2003 and 2009.
    I've got:
    Verilog by Example, Blaine C Readler, first published 2011, short, cheap (£15.50 on Amazon) and simple, aimed at FPGA, not  a bad start
    Verilog Quick Start, 3rd Edition, James M Lee, 2002, expensive, not a bad book but dated, beware 2013 paperback which is  a reprint of the 1997 edition !!
    System Verilog Golden Reference Guide, Doulos, 2012 (there may be  a later edition), cheap for what it is, not a tutorial
    If you can afford it consider buying Verilog by Example, otherwise use free stuff on the web, but beware - a LOT of what you will read is just plain wrong, and a lot will be dated or bad practice.
    Out of interest (I'm not trying to persuade you to change your mind) why did you decide to learn Verilog  (rather than VHDL)?
    MK
  • michaelkellett
    I've got:
    MK
  • msimon
    msimon over 8 years ago in reply to michaelkellett
    Thank you michaelkellett
    I have the second edition which is published in 2003 and the book is solely based on Verilog. But, I will be looking for the System Verilog also on the internet so that I can learn the new things on the language. Your recommended book Verilog by Example looks interesting, I will check it.
    I will start PhD in November and the group I will be joining using Verilog. That is why I decided to learn it. I know I can still design in VHDL and EDA tools combine both languages but working on the same language will be beneficial for collaboration with others.
    Thanks,
    Mehmet
