Legacy Personal Blogs Oooh.....Goody box.
  • Author Author: Andrew J
  • Date Created: 27 Nov 2019 1:47 PM Date Created
  • Views 2305 views
  • Likes 13 likes
  • Comments 14 comments
Oooh.....Goody box.
Andrew J
Andrew J
27 Nov 2019
Look what arrived today:
Could it possibly be...?
Yes!
It's a 10Kg/22lbs behemoth!  Now all I need to find is a UK power cable! image
With many, many thanks to James, baldengineer, and Element 14.  It was awesome to get selected and this has definitely gone to a good home - I'm looking forward to putting it to good use.
Out of curiosity, and because I've not been able to do such a test yet, I thought I'd start off with a comparison to the PS I have just finished building so I set the two up with a test circuit:
Yaps is driving the circuit on the left, Tenma the one on the left.  Both supplies are voltage limited at 5V; the resolution of the Tenma display isn't enough to display current but it's likely to be the same as YAPS at around 10-15mV given both circuits are exactly the same.
It's a 555 timer with 74HC393 binary counter outputting to a number of 74HCnn Logic chips to drive the LEDs.  These cycle through digits 1 - 6 as a dice - not visible in the pic as they're a bit bright!  It's a circuit that Charles Platt created for his Make: Electronics book and it seemed useful for this purpose.  I actually created a video of the circuits running if you're interested.
I just wanted to do a quick comparison of ripple and noise whilst the supplies where driving the circuit.  I've clipped the probes to the supplies' outputs and it's not ideal as I've had to use the probes' earth fly lead and connect to short pieces of hook-up wire as I just couldn't get the probes to clip on to the terminals directly.  Here's the scope output:
Channels 1 Yellow and 2 Pink are YAPS; 3 Cyan and 4 Green are Tenma.  2 and 4 are measuring AC noise.  Measured values, Pk-Pk are:
Channel 1: 0.014V
Channel 3: 0.014V
Channel 2: 0.36mV
Channel 4: 0.46mV
That's as close as makes no difference and over a number of samples, stayed consistent with each other.  Given one is SMPS and one is linear, I expect that with different circuits/loads they'd have different characteristics and I'll discover those as I use them.
  • Andrew J
    Andrew J over 6 years ago in reply to shabaz +4
    Those black studs look like they should move, but don't - they just sort of bend around a bit and feel like they're going to snap off. Nothing in the data sheet about them either so I just assumed they…
  • e14phil
    e14phil over 6 years ago +3
    FANCY
  • three-phase
    three-phase over 6 years ago +3
    Congratulations on the win, hope it gives you many years service. Kind regards.
  • baldengineer
    baldengineer over 6 years ago
    Oh and side note, sorry, I meant to send you note to say you'd need to supply your own power cable! But, I switched the input voltage for you... image
    Jan Cumps over 6 years ago in reply to baldengineer
    Does it deliver 50 or 60 Hz DC?
  • Andrew J
    Andrew J over 6 years ago in reply to Jan Cumps
    Does DC have a frequency?  I mean, there is some ripple on the output but would that be measured at 50/60Hz?  Beyond my understanding I'm afraid Jan.
  • baldengineer
    baldengineer over 6 years ago in reply to Jan Cumps
    Fortunately, neither. image
  • baldengineer
