Legacy Personal Blogs openPicus Flyport WIFI
  • Author Author: robotonics
  • Date Created: 2 Feb 2012 10:28 AM Date Created
  • Views 2027 views
  • Comments 12 comments
  • openpicus
robotonics
robotonics
2 Feb 2012
I have tried to develop an application using the MRF24WB0MA Wifi module from Microchip. I had no problem building a board, however, I had huge problems unravelling code for the TCP/IP stack.
All code provided by Microchip is intended to be used in conjunction with the relevant daughter boards, and development kits, such as the PIC18 Explorer kit. After looking on the internet for some sample code, or a similar project that I could adapt, I found openPicus Flyport!
I could not afford to purchase a Flyport Wifi module for myself, and had all components needed to create one, schematics are freely available for download. Therefore I have attempted to build one myself.
This blog will contain details on the build of a prototype and relevant test and development notes.
  • robotonics
    robotonics over 14 years ago +1
    I have fixed the printing problem, so the circuit could now be completed. I have purchased a lot of 47 sheets of HP Premium Inkjet transparencies on Ebay. The difference in finish between the HP and previously…
  • robotonics
    The difference in finish between the HP and previously used Ryman Inkjet Transparencies is astonishing.  I am using a Canon MP270 Inkjet printer with  Standard / High quality / Plain Paper setting, and the results are excellent for very fine pitch IC's. So far I have managed to create a board that has a 132 pin Hirose connector, with 0.254mm traces connecting to it.
    The question now is, is it worth the effort? I think I would be wise to research wireless modules again, see if there are any new products out there.
    I am a little disapointed with Microchip for not making more effort with their wireless modules, does anyone else feel the same?
  • fustini
    fustini over 14 years ago in reply to robotonics
    Nice looking board!  I'm trying to recall - is that particular connector used in order to connect to the PIC24 dev board?
  • fustini
  • robotonics
    robotonics over 14 years ago in reply to fustini
    Hi Drew
    Yes, it is the (Hirose)-FX10A-120S/12-SV(71) - Receptacle(Hirose)-FX10A-120S/12-SV(71) - Receptacle, The PIC24EP512GU810-I/PFPIC24EP512GU810-I/PF USB Starter Kit connects to it, there is also a MRF24WB0MA wifi module on the back of the board, the other 8 pin molex is for a temp sensor circuit I made using a TCN75 sensor. The connector was quite easy to work with, which was a surprise as I had doubts that the circuit traces would etch properly, with the limited system I use at home.
  • fustini
    Nice work - is it tough to solder on the MRF24WB0MA?
  • fustini
    oh, and just saw, congrats on being the member of the month!
  • robotonics
    Hi Drew
    The MRF24WB0MA is very easy to solder, it has been on and off a few boards now! I usually put a little card underneath it and remove after soldering, that way I get a tiny air gap, and then when I wash and rebake the board it dries out properly. In the past I have had issues with it when not using the card.
  • robotonics
    Thanks, was a big surprise!...now I am looking forward to goodies! image
