Legacy Personal Blogs Picroft: Opensource Voice Assistant on Pi | Raspberry Pi
  • Author Author: oksbwn
  • Date Created: 24 Apr 2020 11:47 AM Date Created
  • Views 2425 views
  • raspberrypi-setup
  • mycroft
  • voiceassistant
  • respeaker
  • raspberrypi
  • hat
oksbwn
oksbwn
24 Apr 2020
This video is all about the installation of Picroft on Raspberry Pi. Picroft is the OS based on Rasbian Lite and Mycroft installed on top of it. Mycroft is a digital voice assistant written mostly in Python. As Mycroft is opensource, this opens up a lot of potentials to add features. As pi does not come with any sort of audio input, I have used a Respeaker 2-MIC HAT from Seeedstudio. This works pretty fine. I have also added some python scripts to use the 3 RGB LEDs available on the HAT, to depict some visual feedback by interacting with the MessageBUS.
Relevant Links:
  1. Mycroft Website
  2. Stable PiCroft Version
  3. Raspberry Pi Imager In Action
  4. Mycroft MessageBus
  5. Mycroft Account
  6. Respeaker 2 MIC HAT
  7. LED Effects/Service GitHub Repo
  8. Respeaker 2 MIC HAT with Raspberry Pi
    shabaz over 6 years ago +1
    Hi Bikash, Any reason you're using these bit/ly links instead of the full URLs? It doesn't make sense to use shortened links unless you expect people to manually type them out. What you have now _all_…
  • oksbwn
    oksbwn over 6 years ago in reply to shabaz
    Hey Shabaz,
    Thanks !! I missed that perhaps during pasting the links go tmessed up. I usually use bitly links in my video description and copied the same to the post. Will sort those out.
    Thanks again.
    Bikash
    Hi Bikash,
    What you have now _all_ seem to be youtube links, so something has gone wrong with the way you've done it, unless you really do expect people to watch 8 videos.
    Also, once you have the full (non-bit.ly) URLs, there is a better way to hyperlink. You can highlight the text that describes the content, and then click on the hyperlink icon in the editor.
    More detail here: Using Editor Tools for Blog Posts
