Legacy Personal Blogs raspberry pi help
  • Author Author: lm386
  • Date Created: 28 Jul 2014 1:31 PM Date Created
  • Views 661 views
  • raspberry
  • problem
  • help
  • pi
  • power
raspberry pi help
lm386
lm386
28 Jul 2014
i have been sing my raspberry pi as usual and suddenly it turned off. the power light dimmed and then completely went off. i tried sing the test points on the pi and they only read 1.37 volts. i use the normal micro usb plug to power it with a power supply rated at 5 volts at 2 amps. it is broken?
the poly fuse is not blown?
thanks michael
  • hawkeyethehacker
    hawkeyethehacker over 12 years ago
    Sorry if this is a stupid question, but have you been holding the silver capacitor when you have plugged it in? I did that to mine and snapped it.
    EDIT: Same Dim power light when an SD card is plugged in? Have you tried swapping the power supply?
  • lm386
    lm386 over 12 years ago in reply to hawkeyethehacker
    i found out when i desoldered the capacitor it was blown so i just replaced it with a through hole 220 uf capacitor that i bent the leads sideways and found out it worked fine again!
  • lm386
