Legacy Personal Blogs Road Test for EATON's SmartWire System
  • Author Author: jeastwood
  • Date Created: 29 Apr 2013 6:00 PM Date Created
  • Views 959 views
  • smartwire
jeastwood
jeastwood
29 Apr 2013
Eaton’s SmartWire-DT Element 14 Road Test
Background
I work at an aircraft repair facility in the R&D Department and am involved with the designing and building of test equipment for testing various aircraft systems; electronic, electrical, hydraulic, instrumentation, pressurization. Most of the test equipment we build is custom for each application.
What is it?
The Eaton SmartWire system is a set of industrial controls designed for ease of wiring and implementation.
The evaluation package included everything needed to try out the system except a computer. The items included:
1.      Easy 802 programmable relay with SmartWire-DT
2.      Contactors
3.      Contactor modules
4.      Start- Stop switches
5.      LED modules
6.      Assembled ribbon cable
7.      Programming software
8.      Programming cable
Initial Impression
Assembly – the assembly and electrical hookup went together without any problems, with the cable being pre-built for the road test kit – following the instructions was almost not required.
The supplied software installed and ran without any issues (on Windows 7).
Using the software required reading the instructions – not that they were difficult, but some of the steps were dependent on prior steps.
1.      Build the setup in software – pick all of the components and place them on the assembly panel.
2.      Build the ladder logic of how you want the system to respond to input actions. – This is where any prior PLC programming experience would be helpful.
3.      Download the program to SmartWire System
4.      See it work.
Pros:
·        Easy to make changes to program –i.e. make changes to how it operates without having to make control wiring changes
·        Wiring is simple, and a much cleaner looking layout.
·        It can be integrated with other equipment.
Cons:
·        Has a slightly higher cost than non SmartWire components.
·        Initial cost outlay for crimper, download cable and software (there is a free version available for download).
·        Knowing basic Ladder Logic is required.
·        Start/Stop Switches did not quite seem to be rugged enough for use in several locations in our facility.
Conclusion:
I liked the fact I was able to get the system wired, software installed, programming completed and downloaded to the controller all in under 1 hour. I would definitely consider using SmartWire in a future project.
    John,
    From the earlier post, I thought the ribbon cable look a bit difficult to rout in the panel.
    I realize that there was no Panduit in the panel.  The ribbon cable was hanging from the components and laced across the tops.
    Is it possible to fold the ribbon cable back to the back-panel, then down and into Panduit?
    Thanks.
    John,
    Thanks.
