Legacy Personal Blogs Robot's cunstruction
  • Date Created: 17 Oct 2012 6:26 PM Date Created
  • Views 1625 views
  • Comments 8 comments
e14 Contributor
e14 Contributor
17 Oct 2012
Finally I have finished the construction of my 5-legged walking robot. It is 30 cm height and weights 2.1 kg.
In the picture bellow, there is a set of parts before assembling:
And a result after assembling:
Robot's control system is based on the STM32F4 microcontroller. It is equipped with a rich set of sensors, shown on the diagram below. Robot is controlled from a PC through Bluetooth interface.
The robot is powered from a Li-pol battery (2100 mAh, 11.1 V). On the PCB there is an integrated charging and balancing system for the battery. There is also a buck converter to power all 15 servomotors from a voltage of 6 V.
The main objective of this project was to create a five legged vehicle and to evaluate its walking abilities. The secondary goal was to obtain an affordable robotic platform, which will facilitate further research.
In the future I will place here a video of working robot.
    e14 Contributor over 10 years ago in reply to balearicdynamics +2
    There are a lot of 6 legged robots and it is a well known subject. I wanted to built something less common and test it. The gait of this 5 legged robot is stable and can change its direction of movement…
    DAB over 13 years ago +1
    I am curious, why did you use five legs instead of six? I know that five legs can still get you the stability you need, so I am interested in how stable it will be. Just a thought, DAB
    Just a thought,
  • clem57
    clem57 over 10 years ago in reply to DAB
    Maybe same reason we have 5 fingers? Six was not needed.
    Clem
  • clem57
    Clem
