Legacy Personal Blogs robotic vacuum defeated
  • Author Author: littleben1
  • Date Created: 9 Oct 2018 4:37 AM Date Created
  • Views 687 views
littleben1
littleben1
9 Oct 2018
So spent a very long day trying to figure out if the battery on a robotic vacuum was bad or not, due to the fact that it wouldn't charge. I've had this project sitting around for awhile and I'm kind of ashamed to admit that it is a friends vacuum and should have had it back to her a long time ago. Anyways, after a while of checking the charger and then also checking the battery (which seemed to hold a charge) I noticed that the charge voltage was not making it through the bot itself, so figured it had to be on the charge board. Push come to shove and sure enough turned out to be the mosfet on the charge board, going to venture a guess and figure that it probably got hit by lightning. Anyways, after all is said and done the thing should be fixed after a quick soldering on of an 86 cent part. Today, was a good day, lol.
  • littleben1
    littleben1 over 8 years ago in reply to 14rhb +2
    Also I say today was all good but I did lose my favorite multimeter (been through a lot and finally gave up the ghost) so there was a black spot on the day. The funeral is tomorrow afternoon.
  • 14rhb
    14rhb over 8 years ago +1
    Hi Benjamin, Good to hear you made a successful diagnosis and repair. At least you are not alone in spending a while mending othe peple's electronics: https://www.element14.com/community/polls/2757#start…
  • 14rhb
    Hi Benjamin,
    Good to hear you made a successful diagnosis and repair. At least you are not alone in spending a while mending othe peple's electronics: https://www.element14.com/community/polls/2757#start=25
    Rod
  • 14rhb
    Hi Benjamin,
    Rod
  • littleben1
    Unfortunately, where I live is pretty rural and nobody knows how to work on computers.....except me....Sometimes its a good thing, sometimes it's a bad thing. I also end up hooking up the local high schooler's stereo systems as well. Now if I could ever get around to getting those last few tubes that I'm collecting for my homemade guitar amp, but I know that one will still be a few years.
  • littleben1
