Legacy Personal Blogs Schematic of the Build
  • Author Author: sasquatch84
  • Date Created: 1 Sep 2017 5:48 AM Date Created
  • Views 1354 views
  • Comments 5 comments
sasquatch84
sasquatch84
1 Sep 2017
So here's a schematic of the build.  I'm not sure I made the schematic very accurate when it came to the relay since on the schematic I was confused as to the purpose of each connection.  In real life, I have the relay powered off of the 5 volt converter, and pin 8 on the Nano controlling it.  I have the ground for the solenoid running through the relay.
Any questions/ideas why the arduino is acting funny (see last post)?
    beacon_dave over 9 years ago +1
    As drawn, the NC contact of your relay appears to short out your +5v rail from the voltage regulator. However, presumably you are still using the opto-isolated relay board.
  • sasquatch84
    sasquatch84 over 9 years ago in reply to beacon_dave
    I made this schmatic at almost midnight so definitely made a bit of a mess.  I'll make some changes here
  • sasquatch84
  • sasquatch84
    sasquatch84 over 9 years ago in reply to sasquatch84
    Actually, I still do know how that relay is supposed to look here.  It is hooked up properly, though.
    beacon_dave over 9 years ago in reply to sasquatch84
    Normally you would either draw the relay board as a box component showing just the connections to the relay board (and refer people to a separate schematic for the actual components on the relay board), or if it is a simple circuit then include the schematic of the relay board and draw a dashed line around it to indicate that it is a separate self-contained circuit.
