Legacy Personal Blogs SMD soldering The FaceDancer11 designed by Travis Goodspeed
  • Author Author: fidelsalinas
  • Date Created: 14 Jun 2013 3:57 AM Date Created
  • Views 925 views
  • msp430f2418
  • ft232r
  • goodfet_facedancer11
  • smd_sodering
  • fuzzing
  • security_products
  • max3420e
fidelsalinas
fidelsalinas
14 Jun 2013
A little step by step SMD soldering image
http://goodfet.sourceforge.net/
http://goodfet.sourceforge.net/hardware/facedancer11/
The purpose of this board is to allow USB devices to be written in host-side Python, so that one workstation can fuzz-test the USB device drivers of another host. There are also a ton of other cool things you can do with your own Python scripts.
First I picked all the big components, 2 Mini USB females, 1 FT232RL(SSOP28), 1 MSP430F2618TPM(QFP64). MAX3420E(LQFP32) and 12MHz SMD Crystal.
Next I added a bit of flux to the board to help stop bridging.
The first componets I soldered are the Mini USBs starting with the outside tabs then the data connetions.
Next on the list is the MSP430 using a one sided chiseled tip and the drag method, be careful not too use to much solder I hold the chip down with a non-conductive plastic wires twisters to center and tack one side.
Now for the FTDI using the same method but lesser pins makes it much easier image
Now for the Max same method but even easier then the last two ICs
Next the 12Mhz crystal
now use a magnifying glass to make sure there are no bridges. It's time for the 0630 parts 2 1.0uF Capacitors, 3 0.1uF Decoupling Capacitors. 2 18pF Capacitors 2 330ohm LED resistors and 3 LEDS
I used non conductive tweezers and just a tack of solder for the caps and LEDs
Once everyhing is soldered on give it a look under a magnifying glass
If everything looks good, connect it and the LEDs should blink, then go to the site above to load the firmware and have some fun.
I hope you enjoyed my post. when the headers I ordered come in I'll post a video of soldering them on the Freescale FRM-KL25Z Freedom.
Thanks for reading
F/S
  • fustini
    fustini over 13 years ago +1
    Very nice! I learned surface mount soldering while making the GoodFET. Travis stopped by our hackerspace in Chicago, Pumping Station: One, in 2010 and did a GoodFET workshop
  • fidelsalinas
    fidelsalinas over 13 years ago in reply to fustini +1
    Yeah, Travis' GoodFet line are handy dev boards to have around tons of neat features, I've been working on windows support for the latests boards. It's cool of Travis' to have stopped by your hackerspace…
  • fustini
    fustini over 13 years ago in reply to fidelsalinas +1
    Neighborly - for sure! We had a fun event that summer, too, called NeighborCon Chicago: http://www.flickr.com/photos/opacity/sets/72157624339808243/ ... aw, miss Travis
  • fustini
    Very nice!  I learned surface mount soldering while making the GoodFET.  Travis stopped by our hackerspace in Chicago, Pumping Station: One, in 2010 and did a GoodFET workshop image
  • fustini
  • fidelsalinas
    Yeah, Travis' GoodFet line are handy dev boards to have around tons of neat features, I've been working on windows support for the latests boards. It's cool of Travis' to have stopped by your hackerspace, he's is just neighborly like that. image
  • fustini
    Neighborly - for sure!  We had a fun event that summer, too, called NeighborCon Chicago: http://www.flickr.com/photos/opacity/sets/72157624339808243/ ... aw, miss Travis image
  • fidelsalinas
    Looks like you all had a neighborly time, we don't have any hackerspaces in my area... I miss living in San Antonio. But I've been working on starting one in my area and hopefully we can host cool events like that soon.
