Legacy Personal Blogs Stuff trickles in and challenges continue
  • Author Author: funinalaska
  • Date Created: 31 Oct 2013 6:43 AM Date Created
  • Views 767 views
  • temperature
  • arduino_weather
  • mail
  • arduino_display
funinalaska
funinalaska
31 Oct 2013
So I got more things in the mail today that I will eventually need to utilize.
I received:
Ethernet shield
More LEDs (gonna make a cube eventually when I need a change of pace and have time)
a DHT22 sensor
I am still waiting for a decent amount of things to arrive, but and also significantly behind on learning how to use things.
I am struggling with learning how to utilize 7 segment displays using multiplexing, but I am sure eventually I will figure that out.
I am beginning to look at the final idea I have for my weather center project and am beginning to worry about my power supply. i think I may need to get a larger 5V regulated supply than what the arduino produced when I add in 3 different displays including LED matrix and 3 digit 7 segment and LCD with backlight. I am planning to use an arduino mega for the final project, but still unsure if it will be sufficient.
I am beginning to realize that this is a VERY ambitious project for a beginner, I hope I don't get discouraged.
I am hoping that when I am done with this project that I will be happy with the results and that it will be used for a long time.
The big issue up here is the extremes of temperature.
I would like to find a better temperature sensor to use outside that has a little lower tolerance for cold temperatures. Our normal low temps are pushing the bottom of most of the affordable digital sensors I have looked at and that I can get libraries for the arduino for.
  • funinalaska
    funinalaska over 13 years ago in reply to DAB
    Ya it is exciting,
    and yes, I am already getting to that point of where do I start, but I figure that learning each component individually is a good place to begin.
    Speaking of I am still having issues with 7 segment displays, But I am short on time this week so hopefully next week I will have more time to try to figure this one out.
    Then next I need to learn the ethernet shield, I am sure that will take me a month.
    I hope my second UNO gets here soon so I can stop completely disassembling one project before starting another.
    DAB over 13 years ago
    Hi Andrew,
    Yea that early phase while to toys arrive is always exciting.
    After a while, you look at all of the boxes and say "Where do I start?"
    Just follow the engineering process, take it step by step and have fun.  The excitement is just beginning.
