Legacy Personal Blogs The Gold of the Fool and the Whiskers of the Cat
  • Author Author: jc2048
  • Date Created: 13 Jun 2017 1:53 PM Date Created
  • Views 3072 views
  • Likes 12 likes
  • Comments 17 comments
jc2048
jc2048
13 Jun 2017
Back in February, I visited one of the small museums that exist in the town where I
live. It's a natural history museum and is based in an old church. It's a lovely
place to visit, with lots of curious things to look at. In the shop, on the way out,
there was a basket with small chunks of rocks and minerals for sale and I bought a
small piece of 'fool's gold' (iron pyrites); I figured that an old fool like me
deserved a piece of gold to treasure.
What I didn't know back then and have only just discovered is that iron pyrites is
a semiconductor (thank you, Wikipedia!) and in the old days was sometimes used as
the 'crystal' in a point-contact diode (for demodulating radio signals in a crystal
set).
Well, I thought, that deserves an experiment. So here is my attempt to make a
point-contact diode, and it turned out to be surprisingly easy. I simply broke one
of the small cubes away and held it in one clip of a 'helping hand' contraption.
That clip I connected to the ground of a signal generator. The drive from the
generator I fed through a 10k resistor to a piece of wire-wrap wire which I arranged
to scrape across the surface of the cube. My scope then measured the output from my
improvised diode.
A little movement of the wire and I soon found a spot that rectified nicely [I was just
so surprised - I really didn't think that this was going to work].
The forward voltage looks to be a little over a volt. That's much higher than a
silicon metal-junction diode (a Schottky diode).
And that's it. No need to melt silica in an oven and grow it into a crystal with
99.99-whatever % purity. Instead, an instant semiconductor straight from nature.
Do I get a cat badge for this foolishness?
    balearicdynamics over 9 years ago +6
    The "radio" based on the crystal was the absolutely first stuff I have done when I was about 10 y.o. Synth was based on the semiconductor crystal (it was the early '70 so these stuff was not difficult…
  • jc2048
    jc2048 over 9 years ago in reply to shabaz +6
    Here's a ZN414 radio I built soon after they launched it (the ZN414 is the part that looks like a transistor, even though it's an IC). Tuning cap was a modified trimmer. Power was a small hearing-aid battery…
  • rachaelp
    rachaelp over 9 years ago +5
    Very impressive. Whatever made you think of doing this? I don't have a badge, but you can be awarded Top Cat of the day if you like?
  • e14phil
    e14phil over 9 years ago
    jc2048 This is one of the best piece of practical experimentation I have seen in ages! What great work :-)
  • e14phil
