Legacy Personal Blogs The Gold of the Fool and the Whiskers of the Cat
  • Author Author: jc2048
  • Date Created: 13 Jun 2017 1:53 PM Date Created
  • Views 3084 views
  • Likes 12 likes
  • Comments 17 comments
jc2048
jc2048
13 Jun 2017
Back in February, I visited one of the small museums that exist in the town where I
live. It's a natural history museum and is based in an old church. It's a lovely
place to visit, with lots of curious things to look at. In the shop, on the way out,
there was a basket with small chunks of rocks and minerals for sale and I bought a
small piece of 'fool's gold' (iron pyrites); I figured that an old fool like me
deserved a piece of gold to treasure.
What I didn't know back then and have only just discovered is that iron pyrites is
a semiconductor (thank you, Wikipedia!) and in the old days was sometimes used as
the 'crystal' in a point-contact diode (for demodulating radio signals in a crystal
set).
Well, I thought, that deserves an experiment. So here is my attempt to make a
point-contact diode, and it turned out to be surprisingly easy. I simply broke one
of the small cubes away and held it in one clip of a 'helping hand' contraption.
That clip I connected to the ground of a signal generator. The drive from the
generator I fed through a 10k resistor to a piece of wire-wrap wire which I arranged
to scrape across the surface of the cube. My scope then measured the output from my
improvised diode.
A little movement of the wire and I soon found a spot that rectified nicely [I was just
so surprised - I really didn't think that this was going to work].
The forward voltage looks to be a little over a volt. That's much higher than a
silicon metal-junction diode (a Schottky diode).
And that's it. No need to melt silica in an oven and grow it into a crystal with
99.99-whatever % purity. Instead, an instant semiconductor straight from nature.
Do I get a cat badge for this foolishness?
    balearicdynamics over 9 years ago +6
    The "radio" based on the crystal was the absolutely first stuff I have done when I was about 10 y.o. Synth was based on the semiconductor crystal (it was the early '70 so these stuff was not difficult…
  • jc2048
    jc2048 over 9 years ago in reply to shabaz +6
    Here's a ZN414 radio I built soon after they launched it (the ZN414 is the part that looks like a transistor, even though it's an IC). Tuning cap was a modified trimmer. Power was a small hearing-aid battery…
  • rachaelp
    rachaelp over 9 years ago +5
    Very impressive. Whatever made you think of doing this? I don't have a badge, but you can be awarded Top Cat of the day if you like?
    DAB over 9 years ago
    Excellent job.
    Now if you want to know something really cool, I can show you why permanent magnets work.
    Excellent job.
  • jc2048
    jc2048 over 9 years ago in reply to DAB
    Thanks, DAB.
    Create a blog post on the subject (you'll need to find an electronics angle to it of course, but that shouldn't be too difficult given how intimately magnetism is tied to electricity) and I promise I'll read it.
    DAB over 9 years ago in reply to jc2048
    I will work on it.
    I have some time now that my book is about to be released.
    The intriguing issue is that I can now show why permanent magnets work and still follow Maxwell's Equations.
    The reason the pyrite works as a semiconductor has to do with the crystal structure and how the photons flow through the wire and into the crystal.  I still need to look more deeply into what you have done, but your experiment follows my theory quite nicely.
