Legacy Personal Blogs The Varieties of Electronic Engineers
  • Author Author: bluescreen
  • Date Created: 20 Mar 2015 4:40 PM Date Created
  • Views 2571 views
  • Comments 19 comments
bluescreen
bluescreen
20 Mar 2015
Electronic Engineer
Electrical Engineer
Double E
Eazy E
  • johnbeetem
    johnbeetem over 11 years ago +3
    Images 1 + 2 not credible: work surfaces need more clutter. Images 1 + 2: where are the ground straps? Is that a ground strap around #1's left forearm? Image 1 not credible: I see the close-up image, but…
  • Problemchild
    Problemchild over 11 years ago in reply to mcb1 +3
    Of course they are publicity shots they are all looking intent and happy, where as any engineer that has got his probes out will be wracked off because something isn't working. Also who on earth has a…
  • Problemchild
    Problemchild over 11 years ago in reply to johnbeetem +3
    In London most of the repair guys look more like number 4!
  • johnbeetem
    Image 1 not credible: I see the close-up image, but not the camera.
    Image 3 is credible, except for lack of coffee stains on work surface.
  • michaelwylie
    michaelwylie over 11 years ago in reply to johnbeetem
    I've never seen anyone outside of a production environment wearing a grounding strap. image
    mcb1 over 11 years ago in reply to michaelwylie
    Best I avoid the repair shops you frequent.
  • michaelwylie
    michaelwylie over 11 years ago in reply to mcb1
    Ahhh, O.K. repair shops I've seen use them. I guess I should have limited it to engineering prototyping areas. image
  • johnbeetem
    johnbeetem over 11 years ago in reply to michaelwylie
    When I'm debugging the first prototype of a board I like to protect it so I don't lose weeks getting a replacement -- not to mention the cost of a prototype.  Usually I'm lazy and touch a connector shell before I probe signals rather than finding a grounding strap.  It depends on the weather.
    One place I worked encouraged engineering not to use static protection because we wanted to see how robust they'd be in customer hands.  But this was in Virginia, so it was rarely dry enough for static problems image
  • Problemchild
    More likely mildew like here in the UK image
  • Problemchild
    I had a strap even at a local repair shop 20+ years ago and a set of metal kickers that you put over your shoes when I worked for Sun, we even had to test the impedance of them by standing on a plate and would have to change them if it went too high.
    That said If  I'm just working on something quickly which is most of the time now I just touch chassis ground. Fortunately the UK is mostly never dry enough for big potentials to grow unless it's been really air-conditioned!
  • Problemchild
