Legacy Personal Blogs TI Launchpad MSP432 Memory SD and Energia.nu
  • Author Author: martinvalencia
  • Date Created: 7 Feb 2016 4:46 PM Date Created
  • Views 3606 views
  • Comments 12 comments
  • datalog
  • energia
  • launch-pad
  • msp432
  • memory-card
  • sd
  • sp:texas_instruments
martinvalencia
martinvalencia
7 Feb 2016
A few months ago my partner mohammedtowhidun, Start your project and one of the tasks that it should be was to control an SD memory card with the launchpad MSP432 of Texas Instruments, he after searching many blogs on the internet can found the great blog by shabaz, who implemented a Data Logger with TM4C123G Launchpad.
in this blog I present the operation of libraries for MSP432, with some changes.
Blog's Shabaz / Thank you very much for leading us to the answer
Tiva LaunchPad: Building an Event/Data Logger - Part 1 – SD Card capability
Tiva LaunchPad: Building an Event/Data Logger - Part 2 – Real Time Clock capability
interfacing sd card with msp432
MSP432 SD libraries Click to Download
Connection Diagram
Necessary changes in the program (Energia17)
Implementation
Important
it is necessary that the SD memory only has a FAT format as with other types of memory formats simplmente not work.
Test
Ending
Once again thank you very much for your time shabazand I hope my friend mohammedtowhidun can successfully complete your project
Mis mejores Saludos
Martin V.
    shabaz over 10 years ago +3
    Hi Martin, Oh, that's awesome. Glad you managed to port it across with just a couple of changes! Very nice that the Energia code is so portable across the different platforms. I've had so little time recently…
    e14 Contributor over 10 years ago +3
    Hey Martin, hey shabaz In the first place, thank you so much for sharing this increadible useful information! I've been through many unsuccessful attempts interfacing a SD card with the MSP432 during the…
    Hello shabaz
    martinvalencia
    i used this sd card holder
    SD Speicherkartenmodul - Bausätze / Module - Entwicklerboards - Sonstige Boards - Pollin Electronic
    and the pin out is
    Description                        MSP432                               SD card holder
    CS                                          P 5.0(J2-13)                        7
    MOSI                                    P 4.6(J2-15)                        9
    CLK                                        P 1.5(J1-7)                          11
    MISO                                    P 1.7(J2-14)                        13
    VDD                                      3.3                                         3
    GND                                      GND                                     1
    I am using a 2GB SD card
    i used the library Shabaz had provided
    I have changed the sketch file CS pin as 13 just like Martin has done ..
    when i run the datalogger sketch file I find the follow error
    when i run the cardinfo sketch file this is what i get
    can anyone help me out ???
    CS                                          P 5.0(J2-13)                        7
    MOSI                                    P 4.6(J2-15)                        9
    CLK                                        P 1.5(J1-7)                          11
    VDD                                      3.3                                         3
    GND                                      GND                                     1
    shabaz over 10 years ago in reply to e14 Contributor
    Hi Mohammed,
    Long shot, but could you try a different SD card? Just to eliminate any compatibility/protocol issues. Could you try some recent SD cards from reputable manufacturers? SanDisk Extreme HD 16Gbyte was the one I used - shouldn't be expensive at all, it is a several year old model.
    Hi Mohammed,
