Legacy Personal Blogs Tiny Issue with KEMET's Pyro Sensor module
  • Author Author: mudz
  • Date Created: 12 Oct 2019 6:39 PM Date Created
  • Views 3189 views
  • Comments 13 comments
  • connector
  • pyro_sensor
  • banana
  • kemet_pyro_sensor
  • small_size_sensor
  • kemet
  • ir sensor
mudz
mudz
12 Oct 2019
UPDATE 17 Oct, 2019 :-
After accepting their mistake they told me that they will correct the order and ship me the mentioned cable.
Later, I received their email - This part does not come with the cable. What you received is correct.
Official answer on the link is - Because maker IO is not an official documentation some of the information at times can be incorrect. We have double checked with Kemets site and there is no cable included.
So, If you are going to buy KEMET's SS-430 Sensor Module, Do not forget to purchase JST connector cable with it.
Hello everyone,
Check this video on Kemet's pyro sensor:-
Also this for size comparison with other components,
Check these images for a quick look at KEMET's Pyro Sensor :-
it's connector size comparison :-
    dubbie over 7 years ago +3
    I look forward to seeing some measurements from this sensor. I have used the GridEye sensor and it will be useful to compare with this. Dubbie
  • clem57
    clem57 over 7 years ago +2
    mudz sounds like they are backtracking and leaving you in the cold.
  • clem57
    clem57 over 7 years ago in reply to mudz +2
    Hey mudz . The best source of connectors I can find are these at https://www.molex.com/molex/products/group?key=micro_connectors&channel=products . They have a large catalog so I am sure you can find what…
  • clem57
    Hey mudz
    The module is shipped with a cable to be connected to a JST connector on a Component mounted side of the module (JST p/n is SM05B-SRSS-TB(LF)(SN)).
    Did you not get the cable?
    Look at https://www.digikey.com/en/maker/projects/things-to-consider-when-designing-with-the-kemet-ss-430-sensor-module/b4abe77a5ec247adaa147a165ddfcb3f
  • mudz
    mudz over 7 years ago in reply to clem57
    just had a quick chat with Digi-key:
    Thank you clem57 for the link. They are correcting the part in their inventory.
    - mudz
  • mudz
    - mudz
  • clem57
    Glad they will fix for you...
