Legacy Personal Blogs YAPS Part Twelve Reprise - Design revisited
  • Author Author: Andrew J
  • Date Created: 3 Nov 2019 5:01 PM Date Created
  • Views 1183 views
  • Likes 8 likes
  • Comments 5 comments
  • bench_power_supply
  • bench power supply
Andrew J
Andrew J
3 Nov 2019
Edit: 22/11/19 - updated navigation link
Following the rather disastrous last PCB update, I had it remade with a footprint that could take a 50uH inductor - and 10uH if I wanted to experiment.  Required a little jiggery pokery to fit the other parts around it but I also took the opportunity to rework some of the silk screen, layout, addition of a TVS on the input (D3) and re-size the mounting holes.
It’s all soldered up and back to working again thank goodness - I’m still kicking myself for misreading the 50nH inductor - with a controllable output voltage and current and nothing overheating or blowing.
So the big reveal - has this improved?  For some reason, the scope has stopped recognising the USB key that’s plugged in so excuse the photos of the screen (and the dust!!)  I suspect something wrong with the firmware but that’s a problem for another day.  These readings were measured at the output capacitor with the short-wire ground probe, AC coupled, BW limited, 1x.
1.5A / 15V
10Ohm load with no voltage or current limiting:
0.050A / 0.5V
10Ohm load with current limited to 0.050A and voltage following:
I think I’ve every reason to be happy with these results right?  Mean Pk-Pk ripple voltage of 0.288mV and a max of 1.04mV from a Vin of 24V to an output of 0.5V is worth writing home about, right?
I’ll do more testing - soak testing, voltage overshoot and so on - but I’ve described these on previous posts so I’ll only repost if I see problems, or someone specifically wants to see them.
I’m on to encasement next.  I see the light at the end of the tunnel at last!
Next: Part 13 - Encasement and Wrap Up
Back: Part 12 - Design revisited: reworking the layout and PCB
  • three-phase
    three-phase over 7 years ago +3
    Great to see an update and that you are moving forwards with the project. The results look good to me, was the power supply on its maximum load? Kind regards.
  • Andrew J
    Andrew J over 7 years ago in reply to three-phase +3
    Thanks Don - it's taken a little while to get the board updated, manufactured and delivered but it hasn't been abandoned. And a jaunt to Italy didn't speed things up either! Max specs are 0-15V, 0-3A so…
  • Andrew J
    Andrew J over 7 years ago +1
    I know I said I wouldn't add more details unless significantly different, but I did get a chance to test the ripple at 15V 3A: Still pretty good in my view. At this power, the LT3081 Linear Regulators…
    DAB over 7 years ago
    You might also put the design under various loads. You will find that the noise may change depending upon what you are driving.
  • Andrew J
    Andrew J over 7 years ago in reply to DAB
    I will be revisiting some of my early experiments and I’ll take the opportunity to see how it impacts, particularly how I have impacted the transient characteristics.
