Clem Martins's Blog Why passwords are important...
  • Author Author: clem57
  • Date Created: 3 Oct 2019 1:45 PM Date Created
  • Views 4797 views
  • Likes 8 likes
  • Comments 47 comments
  • keepass
  • password-based encryption
  • change password
clem57
clem57
3 Oct 2019
     I know a lot of you are thinking, why bother about passwords? Well let me clue you in. Many passwords we use are very weak. Let me list a few and show how long it would take to break with modern computers.
        • password     This is in the top 5 common list of passwords used.
        • pickles         This is in the top 2160 common list of passwords used
        • milkbad        This would take 800 milliseconds because just letters and short
        • mIlkBaD       This would take 2 minutes because short and only letters
        • m1ln2aD      This would take 6 minutes. Now we have numbers and mixed letters, but too short and no symbols
        • m1$k3a%     This would take 1 minutes. Ops, not enough to fix the problem. Too short.
        • qwerty12345asdf    Wow! finally one that would take 701,000 years to brute force attack.
        • qw$rty12#45as*f     Adding in the symbols we get 130,000,000 years to brute force attack.
So in conclusion, it takes the following things to make a password strong.
  1. More than 8 characters or even  more than 16 characters.
  2. Upper and lower case. This helps double the choices from 26 to 52.
  3. Add in numbers and symbols. One without the other can weaken the password.
  4. Finally, use a password generator and stored database like KeePass for instance.
If you wish to play around with your choices, I found this great site https://www.comparitech.com/privacy-security-tools/password-strength-test/#password-test-tool .
Give it a spin and comment below on your experience. I would like to know what is the toughest password using the above tool?
Anyone up to the challenge. Oh a password generator does not count! image
  • BigG
    BigG over 6 years ago in reply to Gough Lui +6
    In my opinion, the correct message is that users need long passwords more so than say short "complex" ones. The way I teach my kids about passwords is to type out a long sentence without spaces. It is…
  • glennvanderveer
    glennvanderveer over 6 years ago +5
    There has to be a tradeoff of entropy and usability. If you make the rules to stringent, no one will be able to remember their password. I always think of this comic when someone starts taking about password…
  • Gough Lui
    Gough Lui over 6 years ago +5
    Users need complex passwords - we know that much. Users need to avoid reuse as well - in case any password is compromised. But on the server side, administrators need to do their part as well. For one…
  • clem57
    clem57 over 6 years ago in reply to glennvanderveer
    If you worry about key loggers, I suggest you read https://keepass.info/help/v2/autotype_obfuscation.html . They use a method to stop that:
    The Auto-Type feature of KeePass is very powerful: it sends simulated key presses to other applications. This works with all Windows applications and for the target applications it's not possible to distinguish between real key presses and the ones simulated by Auto-Type. This at the same time is the main disadvantage of Auto-Type, because key loggers can eavesdrop the simulated keys. That's where Two-Channel Auto-Type Obfuscation (TCATO) comes into play.
    Clipboard spies don't work either, because only parts of the sensitive information is transferred on this way.
    Anyway, it's not perfectly secure (and unfortunately cannot be made by theory). None of the currently available key loggers or clipboard spies can eavesdrop an obfuscated auto-type process, but it is theoretically possible to write a dedicated spy application that specialises on logging obfuscated auto-type.
  • glennvanderveer
    Although the article does not say how the first break in happened, it could have been as simple as a visualbasic script that installed a key logger.  It doesn't matter what password rules you follow, key loggers record everything.  At the time of the article, VB scripts where a plague on Microsoft Windows and Office platforms.
  • clem57
    If you think about it, getting into systems by even youth happens. So why make the password too easy? I have the following example:
    https://www.nytimes.com/2000/09/23/us/youth-sentenced-in-government-hacking-case.html
    Enjoy the read and then ask why did they get in so easily, could it have been lax password withing the affected organisations?
    Clem
  • gadget.iom
    gadget.iom over 6 years ago in reply to koudelad
    koudelad  wrote:
    My recommendation is using certificates wherever possible: SSH, remote desktops, etc.
    If I can't use a certificate, I use a strong generated password and store it locally in something like KeePass. I wouldn't trust cloud password managers, there have been security breaches.
    Use two factor authentication for all publicly available services. Nice and open-source application for mobile phones is FreeOTP. Or hardware modules like Yubikey, which gadget.iom  mentioned.
    WebAuthn is showing some promise too. Effectively the security of certificates with the convenience of a button press.
    https://fidoalliance.org/fido2/
  • gadget.iom
    gadget.iom over 6 years ago in reply to glennvanderveer
    There is still an element of chance in this approach. The new password you set could still exist further in the brute force dictionary.
