Don Bertke's Blog Spectral Microscope Blog 2.
  • Author Author: DAB
  • Date Created: 12 Oct 2015 7:57 PM Date Created
  • Views 759 views
  • spectral
  • microscopes
  • stem
  • imaging
  • chemistry
  • science
  • optics
  • biology
  • physics
12 Oct 2015
Hi all,
I did warn you this would be a slowly evolving project.
After seeing the comments from @Douglas Wong  I did some research and  web searches for a more spectrally pure source.
While I appreciate the need for such a source for laboratory spectral information, I realized that most of the techniques I want to share are just as easily shown using the LED source.
So I went to the Adafruit website and ordered the new Neopixel Jewel and a 12 and 16 LED Neopixel Ring.
The Jewel should give me plenty of light intensity for transparency measurements and the Rings should do the same for surface reflectance measurements.
And yes, I was going to add some photo's, but I found the camera had been left on, so the battery is charging and I should have some pictures and design sketches for you on the next update.
That is all for now.
    DAB over 11 years ago in reply to mcb1 +1
    Hi Mark, Yes, I read your post with interest and I am really counting on them being bright. The big problem with microscopes is that you lose brightness with magnification. So at 10X, you have 1/10 the…
    Hi Mark,
    The big problem with microscopes is that you lose brightness with magnification.  So at 10X, you have 1/10 the light, at 100x you have 1/100 of the light, so depending upon what I will be looking at, over brightness is a good thing.  image
    Plus, I plan to take the spectrum through some very specific increments to see if I can measure some ancillary effects in the spectral region.
    I can always use filters if I need to really cut the brightness, but as I said, I do not think it will be a big problem, though I could be wrong. image
    mcb1 over 11 years ago
    You'll find the NeoPixels extremely bright.
    I had them on 3v3 at one stage, and thought they were good then.
