Don Bertke's Blog Spectral Microscope Blog 2.
  • Author Author: DAB
  • Date Created: 12 Oct 2015 7:57 PM Date Created
  • Views 760 views
  • spectral
  • microscopes
  • stem
  • imaging
  • chemistry
  • science
  • optics
  • biology
  • physics
12 Oct 2015
Hi all,
I did warn you this would be a slowly evolving project.
After seeing the comments from @Douglas Wong  I did some research and  web searches for a more spectrally pure source.
While I appreciate the need for such a source for laboratory spectral information, I realized that most of the techniques I want to share are just as easily shown using the LED source.
So I went to the Adafruit website and ordered the new Neopixel Jewel and a 12 and 16 LED Neopixel Ring.
The Jewel should give me plenty of light intensity for transparency measurements and the Rings should do the same for surface reflectance measurements.
And yes, I was going to add some photo's, but I found the camera had been left on, so the battery is charging and I should have some pictures and design sketches for you on the next update.
That is all for now.
    DAB over 11 years ago in reply to mcb1 +1
    Hi Mark, Yes, I read your post with interest and I am really counting on them being bright. The big problem with microscopes is that you lose brightness with magnification. So at 10X, you have 1/10 the…
    mcb1 over 11 years ago
    You'll find the NeoPixels extremely bright.
    I had them on 3v3 at one stage, and thought they were good then.
    Hi Mark,
    The big problem with microscopes is that you lose brightness with magnification.  So at 10X, you have 1/10 the light, at 100x you have 1/100 of the light, so depending upon what I will be looking at, over brightness is a good thing.  image
    Plus, I plan to take the spectrum through some very specific increments to see if I can measure some ancillary effects in the spectral region.
    I can always use filters if I need to really cut the brightness, but as I said, I do not think it will be a big problem, though I could be wrong. image
    Hi Mark,
