Don Hersey's Blog So I had an idea for some lamps a coupla decades ago. . .
  • Author Author: D_Hersey
  • Date Created: 24 Jan 2015 8:17 PM Date Created
  • Views 2157 views
D_Hersey
D_Hersey
24 Jan 2015
That I had my kids build when they were in grade school.  They bled mightily for the cause, I am obliged to report:
NVM the dead bugs.  Waddya want me to do, clean stuff or learn GIMP?
The kids have long since vamoosed to the edges of the continent, although they still take my calls.
So, I am left with these niggling reminders of their object superiority and fine motor skills.  I can tolerate this no further.
I have decided to make a pair of lamps of my own manufacture.
[small stellated dodecahedron]
here is a model I stole from the internet.  I have a paper model, but someone stepped on it and it is under repair.  When I am done I will update this section.  This is an icosadodecahedron, spell-checker be damned.  This is an Archimedian solid.  It is the only one whose Petri polygons are planar.  The only Platonic solid with planar Petri polygons is the octahedron.  Some argue that this makes them the most typical examples of their respective symmetry groups.image
So, I want to make three lamps:  One a model of a small stellated dodecahedron, which I will hence abbreviate 'SSD.'  Another an octahedron.  Finally, an icosadodecahedron.  The twist is that I am going with LED illumination rather than incandescent.  Per-face RGB.
In the case of the icosadodecahedron, I plan to make a wooden skeleton.  I will make twenty triangles and twelve pentagons of wood.  They will be void in the middle.  There will be a channel routed around the periphery of the void.  I will cover the voids with white cloth.  I can take a string and a flat, round chisel and smoosh the fabric into place as wood-framed silk screens do:
I will bevel the edges appropriately and grove the edges for a popsicle-stick feather.  Then I can use vacuum-bag technique with slow-drying glue to finish the job of fabbing the skeleton.
Inside, microcontroller-controlled LEDs will shine upon the fabric.  Which brings me to why I am bring this up with you ladies and gentlemen:  I am welcome to ideas about what controller and I/O fabric to use with this project.  I am open to suggestions about what kind of LEDs to use, how to mount them, and what syndromes to employ.  Can we play a game like John Von Neumann's 'Life' here?  Can we model diffusion like a butterfly's wing?
I think I want something I can code in C++ so that I can write a Forth-interpreter for high level syndrome insertion.
I will use a little different technique with the octahedron and SSD:  I just got a nice little table-saw from Craigslist.  Boy, it is a nearly confiscatory environment out there, what with salesmen unloading samples and all. . .  I plan to saw up little strips of machineable wax to make the little isosceles triangles I will need.  They with have a little ledge that will form a lacuna for a triangle of frosted glass.  You can glue machineable wax.  It is paraffin with polyethylene (or polypropylene) dissolved in it to saturation.  This I or a proxy will sandcast with Al.  Otherwise, the idea is the same.
  • D_Hersey
    D_Hersey over 11 years ago in reply to jw0752 +1
    My late friend, Rikki Decay, took me to a horse race one day. I am not a deep political thinker. I adopt the fashionable ideation in hopes of getting chicks, or at least not offending them too much. Schopenhauer…
  • Former Member
    Former Member over 11 years ago in reply to D_Hersey
    I guess I should be happy that mine has skinny legs then.
  • D_Hersey
    My late friend, Rikki Decay, took me to a horse race one day.  I am not a deep political thinker.  I adopt the fashionable ideation in hopes of getting chicks, or at least not offending them too much.  Schopenhauer would have been far more approving of Rikki than myself, he was a far more diligent practitioner of internal jihad than I was, back then.  So I emit the boilerplate:  "This is cruel, look how skinny those horse's legs are!  yada yada"
    "Don," he said, "your hidden predicate assumption is that the horses do not know what is going on.  They know.  They don't get to this level in ignorance.  They know consciously and they know in a Jungian sense.  They are relieved when they are victorious.  This activity is antic.  These cats aren't the enemy of horses, BTW, Henry Ford was the enemy of horses!"
    Hence, I have concluded that if one doesn't put one's kids in play, they reckon that you have no use for them and grow both apprehensive and surly.
    jw0752 over 11 years ago
    You mean you demanded excellence of your kids? Good Job. Too many parents, now days, are happy to let them play video games until their brains decompose. The lamps are beautiful and an special treasure if your boys made them.
