Douglas Wong's Blog Creating a Maker Wish List
  • Author Author: dougw
  • Date Created: 19 Dec 2016 6:46 AM Date Created
  • Views 4144 views
  • Comments 26 comments
  • maker_wish_list
  • christmas_wish_list
  • wish_list
dougw
dougw
19 Dec 2016
For me accumulating a complete set of tools, software, instrumentation and stock to permit building electronics projects has been a long slow process (decades) and it is still going on. This list is my idea of the most effective order in which to acquire new equipment. It takes into account cost and usefulness. I did not exactly follow this path as costs were different when I started - back then a DVM was a very expensive device.
  1. 3.5 digit DVM (DVMs are the most used instruments and they are now low cost)
  2. hand tools (needle nose pliers, side cutters, wire strippers, xacto knife, tweezers, screwdrivers, nut drivers, metal shears, vice grips, hack saw, files)
  3. internet computer (information is the thing that will save you the most time and money)
  4. temperature controlled soldering station (if you do electronic assembly, you cannot get far without one of these)
  5. 5 volt power supply (it is important to have reliable bench power supplies - it will make troubleshooting a lot easier)
  6. stereoscopic microscope (or at least high magnification inspection goggles) electronics are shrinking all the time - it is hard to work effectively if you can't see what you are working on
  7. vice (a vice is a strong third hand that increases your abilities) (I have at least 4 on my bench)
  8. variable power supply (this is the second most used electronics instrument - if it displays voltage and current, it will be a lot more useful)
  9. electric hand drill (electronics need packaging and mechanical interfaces - most projects will need some drilling)
  10. RLC meter (a DVM does some of this and may be sufficient, but sometimes you need to measure these things - it can save a lot of effort)
  11. electronic CAD (the fastest way to design something is if you have it stored from the last time - a real time saver)
  12. oscilloscope (signals are mostly inyteresting when they are changing - and this is the best way to see what they are doing)
  13. drill press (if you want your projects to look good they need accurate mechanics - a drill press is the minimum to get started on accuracy)
  14. frequency generator (these simiulate the output of cicuits and sensors and can save a lot of effort)
  15. electric screwdriver (can save time)
  16. mechanical CAD (when you want your proects to be aesthetically pleasing and consistent and accurate and repeatable, you need CAD)
  17. 3D printer (the lowest cost way to build prototypes in many cases)
  18. hot air rework station (makes SMT work much easier)
By the time you have accumulated this much equipment, you will have enough projects under your belt to know what else you need. For example if you are into radio, there is a different set of equipment that is important than if you are into lighting, or audio, or robotics or IoT or wearables etc.
I have already accumulated more than what is in the above list so I have a fairly complete lab.
Now my wish list is more focused on new modules and parts I would like to embed in electronics projects.
Generally, it is not clear what parts will be needed in future products, but there are some platforms that I expect will be used sooner or later.
I definitely have a couple of Raspberry Pi 3 projects on my to-do list, so they are high on my wish list.
The PSoC Kits are very handy for projects that don't need quite so much horsepower.
And I can always use more 3D printer filament, or if that isn't available a load of Neopixels is bound to find a home sooner or later.
Specific products that are high on my wish list along with why:
Raspberry Pi 3 Model B (I still need one for my Pi IoT project, and I would like to build a Pi arcade system, and maybe an MQTT broker)
PSoC 5 CY8CKIT-059 (the PSoC Creator development environment makes this low-cost Cortex M3 system powerful and easy to use)
PSoC 4  CY8CKIT-043CY8CKIT-043 (likewise the PSoC Creator development environment makes this low-cost Cortex M0 system powerful and super easy to use)
Robox Filament  RBX-PLA-WH170RBX-PLA-WH170 (I am continuously amazed at how many uses I find for my 3D printer - it changes the way I think about a lot of things)
  • Workshopshed
    Workshopshed over 9 years ago in reply to COMPACT +3
    I started a bit later than Compact but had a tiny soldering iron, some side cutters, a scalpel and some pliers. Only recently got a temperature controlled iron and that was one of the best investments…
  • Workshopshed
    Workshopshed over 9 years ago in reply to rachaelp +3
    Ah yes, a desoldering tool. I used a little rubber ball type and braid for years, got one of those spring loaded ones a few years back.
  • Workshopshed
    You probably also avoid the blow torch approach then...
  • rachaelp
    rachaelp over 9 years ago
    Hi Douglas,
    That's a good set of things on that list, all really handy for anybody serious about making things in their own lab. There's probably a few things I would add to that list if I may:
    1. Assorted USB serial widgets e.g RS-232 to USB, TTL to USB etc so you can easily hook up to debug serial ports of development kit.
    2. Cheap JTAG type programmer if you need to flash an MCU (if it's not like an Arduino and already has a boot loader).
    3. Solder fume extractor (Lead free solder is really horrible to breath in so some basic extraction is essential).
    4. Desoldering tool so you can take stuff apart more easily (bare minimum a mechanical pump, ideally a vacuum desoldering station).
    5. Other soldering accessories like a flux pen, solder wick and a couple of sizes of solder depending on what your needs are.
    6. A selection of different cables with different terminations (banana plugs, clips, bnc connectors etc) so you can hook your boards and test equipment up.
    7. Sample books for R's and C's in assorted sizes so your never stuck for such a basic part.
    From your list I would say that you'd probably want a selection of multi meters rather than just one as you often need to measure several things at once (e.g. voltage and current simultaneously, possibly at the input and output).
    I agree a temperature controlled soldering station is a must for anybody serious about electronics, and a range of different tips and accessories for different tasks too. It's amazing how quickly time can disappear trying to get something assembled if you are struggling to get your soldering right so a decent station is an investment in being able to spend more time designing and testing and less time being frustrated trying to rectify a solder covered mess!
    Best Regards,
    Rachael
  • rachaelp
    Hi Douglas,
    Best Regards,
    Rachael
    dougw over 9 years ago in reply to rachaelp
    Excellent suggestions.
  • Workshopshed
  • COMPACT
    COMPACT over 9 years ago in reply to Workshopshed
    I avoid spring loaded Desoldering tools because they are too violent and can damage PCBs by breaking tracks or damaging pads.
    I have a preference for using constant vacuum desoldering stations and guns such as the Hakko FR300-18 - Some cheapie brand ones work well if you get your technique right.
    (I am very surprised not to find a Tenma branded desoldering station (non-SMT).)
    My biggest hint is to use gravity to your advantage or not fight against it. Have the desoldering iron to the side if the PCB is vertical or below if the PCB is horizontal.
    The second is to actually add solder to the joint you want to desolder prior to the desoldering operation.  This additional solder presents a large globule and prevents air leakage to improve the suction effect.
    The third is to have the heat tuned to the lowest temperature possible allowing you to heat up the joint properly and having all of the solder fluid without damaging or burning the fibreglass substrate.
  • Workshopshed
  • rachaelp
    rachaelp over 9 years ago in reply to COMPACT
    I agree, and the spring loaded ones, unless you get a good one can be quite difficult to use too. I think there are some which have squidgy silicone tips which are a bit better than than the really cheap ones with the hard plastic tips. I don't actually own one these days though as I have my Metcal desoldering station and of course, good old solder wicking braid which is brilliant for cleaning up surface mount pads or getting excess solder out from around an IC.
